Moving Coil Step Up Maths and Optimal Matching - Page 6 - diyAudio
Old 9th March 2014, 08:33 PM   #51
andyr is offline andyr  Australia
Originally Posted by kevinkr View Post
I've found for example that the DL-103 is generally quite happy with a termination resistance of 100 ohms into a SS head amp, which is well within the manufacturer recommended range.
Yet my friend's DL103 sounded best at the 5K1 load setting on his G Slee opamp-based 'Elevator'. This was corroborated on my AKSA JFET-based 'Paris' headamp, which uses load plugs in a parallel pair of input RCAs to set loading.
Andy
Old 13th March 2014, 05:02 PM   #52
kevinkr's Avatar
I mostly use transformers, and have not tinkered with the load resistance on my SS head amp. When I had it built I had the option of an extra set of RCA jacks for loading and decided I preferred as few additional connections for a 200 - 300uV signal to flow through as possible, so the load resistance is fixed at 100 ohms as that seems to work well with my SPUs and a DL-103D I still have.
Long ago I experimented extensively with the Monster Alpha II HOMC, the manufacturer recommended 47K and I ended up preferring 1K..
The DL-103 works well at 100 ohms, but could easily work better at some other value - I didn't investigate.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th March 2014, 07:22 PM   #53
The improvement at a 5K1 loading was quite noticeable, compared to 100 ohms.
I would have to say you've never heard your D103 sounding at its best, then.
regards,
Andy
Old 14th March 2014, 12:43 AM   #54
kevinkr's Avatar
It's long gone, it was the first stop on my LOMC journey, without it I would probably have not continued playing vinyl however..
Phonostage with tube moving coil legarem Tubes / Valves 4 13th October 2011 04:42 PM
Moving Coil preamp design paul joyce Solid State 162 26th October 2010 10:36 PM
Moving coil mechanism wanted malti Parts 0 20th April 2010 09:54 AM
Moving Coil cartridge experiment bulgin Analogue Source 13 9th January 2007 07:57 PM
moving coil loading lt cdr data Analogue Source 28 27th June 2005 09:50 PM
Copyright 1999-2017 diyAudio
