Infinity Black Widow Tonearm Lifter Issue
Old 15th February 2014, 02:52 AM   #1
gator1234 is offline gator1234  Canada
Default Infinity Black Widow Tonearm Lifter Issue
I have to repair the lift mechanism on my Black Widow tonearm. The silicone fluid has leaked from the cylinder. Anyone have insight on dis-assembly of the lifter mechanism?
Thanks for any reply.
Old 15th February 2014, 04:30 AM   #2
tvi is offline tvi  Australia
tvi's Avatar
2/3 down this page l-07d repairs they tear down the cue which should be similar to your which looks like a jelco
jelco-ichikawa
The small part of ignorance that we arrange and classify we give the name of knowledge.
Ambrose Bierce
Old 15th February 2014, 01:02 PM   #3
Thanks for the info. Actually the Infinity mechanism does not come apart in the same manner. There is no visible top or bottom section. It obviously was assembled, so it can be dis-assembled, but it is not clear how to do this and I do not want to damage beyond repair!
Old 15th February 2014, 02:24 PM   #4
tvi's Avatar
have you removed the lift mechanism
if you remove the curved arm support and then loosen the retaing screw it should just drop down, hopefully revealing a set screw
Ambrose Bierce
Old 15th February 2014, 06:28 PM   #5
Thanks. I had removed the set screw, but it still will not come apart. Should the top just pull out by grasping the piston and pulling?
Old 16th February 2014, 03:11 PM   #6
tvi's Avatar
it might unscrew like this
more pics try
Fidelity+Research+tonearm+lift
Ambrose Bierce
Old 17th February 2014, 01:06 AM   #7
If only it was that simple! The Black Widow mechanism has no visible top or bottom, just a one piece cylinder. The bottom is a black plug but is recessed so prying out would make a mess of it. I have removed the set screw, the piston will rotate, but not pull out. Any other thoughts?
Thanks for all your help.Click the image to open in full size.
Old 17th February 2014, 02:10 AM   #8
Old 3rd May 2014, 04:45 AM   #9
cmfast is offline cmfast  United States
I have a Black Widow, but my cue is still working fine.
However, on my Sansui SR525 the cue is built the same with no recognizable way to disassemble. It dropped like a stone. Here is what I did..... your mileage may vary.
-remove the set screw on the side. It very likely just mates with a slot in the side of the piston so that is doesn't rotate. It doesn't actually lock anything.
-re-attach the rest/bar at the top that the tonearm rests on.
-Squirt silicone into the hole where the set-screw was, make sure your aligned with the groove on the piston.
-use the "rest" to spin the piston in order to spread the silicone.
-you will have to work it in the up and down positions.
-you may also have to soak the whole unit in alcohol or lighter fluid to clean out the old silicone. If you do, make sure to let it dry thoroughly.
The first time I tried it there was air bubbles that would pop. It's important you realize that the silicone is not a reservoir in the bottom, it's just coating that binds the friction between the piston and cylinder. Hope that helps.
Infinity Black Widow Tonearm Lifter IssueHide this!Advertise here!
Infinity Black Widow Tonearm gator1234 Analogue Source 4 21st January 2014 01:20 AM
Taking apart a Black Widow Tonearm saxonsraven1 Analogue Source 1 2nd March 2013 12:11 PM
Diassembly - Re-wiring Infinity Black Widow Tonearm tvr2500m Analogue Source 2 15th October 2007 04:26 PM
Infinity Black Widow mavz Analogue Source 7 13th February 2004 01:31 AM
Black Widow tonearm setup FrankW Analogue Source 3 13th January 2004 10:33 PM
