Custom TT project complete
Platter/bearing assembly by Choir Audio...Foot parts by Arron Machine shop...acrylic base by Laser Equation...Tonearm by Sound Audio circa 1970...Head shell by Ikeda...Cartridge by Grace model F9...Arm board by Micro Seiki...Controller by Space Tech Labs...Stabilizer by Audio Technica...Platter/bearing assembly, foot parts and acrylic base were all designed on Autocad by me...Behold Arctic Analog Time Machine
Like this 🙂
To add a photo, files or non standard files.
First click "go advanced" in the box below the "quick reply" message box. Doesn't matter if you decide half way through a message to do that, it carries it foward.
Then click "Manage attachements". Maximise the new Window so that you can see all the text.
Click browse in the first box at the top and find your picture. Repeat for any more pictures.
Click upload... a message appears "uploading"
When complete the files will show as being attached. Now click the small text that says "close this window"
The pictures should now be attached and when you submit your post they will appear.
Make sure your pics aren't too big, a couple of 100k is plenty, and many members object when they are massive and it alters the margins
It tells you in the attachments window what max sizes are allowed.
If you want to attach a file that has a non standard format for example excel, circuit simulation etc then try putting the files in a zipped folder and attaching that.
trying again
Time Machine
Thankyou!...This design is actually years in the making...designed about a dozen different TT before I finally decided to go with this one...this design allows 3 arm use with either a Clearaudio Solution type arm board or Micro Seiki as shown in the pics...the foot bolt assembly is also very versatile as it allows user to level TT then lock in place...Height of arm board is also adjustable...
#Stuartarm,
I am speechless. This is awesome. This is not just a TT, but a piece of art. My compliments. What a fine piece of machinery. Does it sound just as good as it looks? If so, which probably is the case, you then must be in audiophile heaven. Congrats!
