5 pin din connection point to point on RCA? - diyAudio
Old 11th January 2014, 07:44 PM   #1
Default 5 pin din connection point to point on RCA?
I am going to build my own tone arm cable but don't know proper connection from female din to RCA jacks...can anyone direct me to a drawing showing the schematic configuration of that...thankyou
Old 12th January 2014, 04:30 AM   #2
I don't have the diagram... and I'll be doing just what you are next week. I plan to use a multimeter and trace the connections from the (usually color-coded) cartridge pins to the male DIN connector coming out of the tonearm. Then I'll write down which DIN pin corresponds to which cartridge pin.
On the cartridge end, the left channel will be white for "positive" and blue for "negative". The right channel will be red for "+" and green for "-". These correspond to the white phono plug for left, and the red phono plug for right. This rhyme helps me remember which is which: "Left is white, red is right".
Alternatively, if you have the old cable, you can trace the pins on that.
Old 12th January 2014, 08:09 PM   #3
good point...I have a multimeter sitting right beside me...was hoping for a drawing...thankyou
Old 20th February 2014, 02:27 AM   #4
looking down on the face of the stock din plug with the holes being at the top there is letters indicating wire connections as follows...centre hole is tonearm ground...left from that is the left channel rca outer then centrepin consecutively...right side of centre hole is the same...first hole right of the tonearm ground is right channel rca outer then center pin consecutively...checked with ohm meter to make sure...this should be standard with most tone arms that are 5 pin din to rca...my first attempt at building my own interconnect for this purpose was rather challenging to say the least...using a cat six 3 pair cable modified by stripping outer jacket and using two of the most tightly twisted pair for music and one other conductor of third pair placed with then drill twisted all together till cable appears as one...a cardas female and good quality rca...heat shrink used where required...my first impression was failed attempt because I could hear hum when none was heard from stock?...I suspect the lack of shield was causing this...moving power cables around (120v and 24v lamp) changed volume of hum...however during record playback I seem to have noticed a sonic improvement over stock that was significant enough to leave it plugged in for now...got more supplies today being more shrink and 1/2" braided shield (that **** aint cheap)...failed when the shrink split after heating with a toaster...off to get a proper heat gun and yet more shrink...this cable will be the most expensive yet and have built a 24 pair cat 6 into a two channel speaker cable...cable was free though lol...cutoffs from different places can be had for free
Old 22nd February 2014, 11:00 PM   #5
After a few slip ups the interconnect is complete and well worth the effort
Old 25th February 2014, 12:44 AM   #6
diyAudio Senior Member
fdegrove's Avatar
Just in case you'd need it later:
Ciao,
Frank
Old 25th February 2014, 07:42 PM   #7
Thanks Frank?...Don't know why this drawing so hard to find off the internet
Old 25th February 2014, 07:59 PM   #8
fdegrove's Avatar
You're welcome.
My first name is Frank indeed.
If, like myself, you need to solder up half a dozen or so a month you'll know how to find that pic, trust me.
Actually, if you google for 5 pin phono-connector, then select images, it should be in there somewhere.
Ciao,
Frank
5-pin DIN to RCA conversion? Hodgie Solid State 8 25th January 2014 08:12 PM
Right-angle 5-pin female DIN for tonearm connection Etnier Parts 7 22nd July 2013 02:58 PM
5-Pin Din to RCA Gauteng sideshowbrett Parts 2 22nd June 2013 07:36 PM
Wiring 5-pin DIN to RCA phloyd Analogue Source 2 6th October 2012 09:14 PM
5 pin din to rca how to. saltyreefguy Parts 1 10th June 2006 10:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
