Here my lartest product of a DIY turntable - diyAudio
Old 16th November 2013, 05:52 PM   #1
Default My DIY turntable
is made of an old EDS1000-2 DD motor from a Dual CS721, the OPS tonearm was taken from a Dual CS5000 and is a extended Version (by me) to 9.5zoll(ca. 242mm instead 221mm of the orginal) with headshell from a CS505-2.
It works very good and quite. In- and outerplatter came from a Linn Sondek.
The three feets are from a Linn Basik.
The OPS tonearm is some very special, it sounds surprisingly good with Audio Technica AT-ML180OCC or Linn K-18II(these cartriges are my alltime favourite MMs since longtime!).
Both Cartridges has get a re-tipping with a ATN150MLX needle.
Old 18th November 2013, 07:42 PM   #2
directdriver's Avatar
Interesting project! What happened to the stock Dual platter? Do you think the Linn platter is an upgrade over the Dual platter?
Old 18th November 2013, 08:00 PM   #3
von Ah is offline von Ah  United States
von Ah's Avatar
That's a Citation Receiver!
Nice table, too.
Old 19th November 2013, 04:11 PM   #4
@directdriver:
The Linn platters are defintely an improvemend (3,6 kg flywheel mass) over the Duals, with Sondek platter Sound seems more serious with cleaner and stronger bass. With the orginal Dual platter(I tried the 2,5kg 701 as well as the 1,5kg 721 platter) were not really flat and kind of windy in Bass region.
@von Ah:
Yes, its THE Citation Receiver!
Old 19th November 2013, 07:16 PM   #5
Default Dual 701/721 projects
One member did something like that along the same line in another thread. Instead of a subplatter + outerplatter, he replaced the stock platter with an acrylic platter.
The Dual motor is full of potentials!
Other projects I found online using the Dual 701 in slate or wood plinths.
Old 19th November 2013, 08:18 PM   #6
Some of the DIY things above around the EDS1000 I had seen in the NET! From there came the idea for my own project from.
Its a nice and uncomplicated DD drive!
For a long time Ive used an precirkus LP12 (about 14years), but when Ive heard the EDS 1000 for the first time in my own design, Ive never get back to my Sondek!
Ive even try a Origin Live SilverIII and EncounterIII tonearm with the EDS1000 with very good results over the LP12. Yes, there is a lot of potential in it!!!!
Old 19th November 2013, 11:17 PM   #7
Default Dual project
Another project from online:
Old 19th November 2013, 11:24 PM   #8
Another one in simple plywood plinth with 12 inch arm.
Old 20th November 2013, 05:36 AM   #9
The last one is a good example for me, want to try a DIY 12 inch tonearm on it.
Have a Ortofon AS212 too, its a good base to do so.
Old 20th November 2013, 09:28 AM   #10
analog_sa's Avatar
I think having such a large surface area plinth made out of resonating material is a very bad idea. Especially if the arm is hard coupled to it. Even the original Dual construction is not nearly as bad as some of the diy stuff on this page. Especially if you are using a Dual arm anyway.
HDMI transmitter: diy, eval board, finished product? RHosch Digital Line Level 15 26th December 2011 06:07 PM
DIY turntable using parts from DIY Hi Fi Supply gadfly Analogue Source 6 9th August 2009 04:59 AM
turntable diy audiofilofine Analogue Source 6 3rd September 2006 12:38 PM
Another decent non-diy product sqlkev Multi-Way 8 23rd June 2006 10:38 PM
DIY turntable anyone? AuroraB Analogue Source 5 20th September 2004 08:29 AM
Copyright 1999-2017 diyAudio
