Thanks very much, kind Sir-from-the-South!
I am not sure what all the pre-sets are doing, particularly which ones are setting gain and feedback - mixing them up can be frustrating. I have an idea of the general Wien-bridge configuration and could possibly figure it out by tracing the p.c. - but asking first is simpler and more convenient! If you do not mind I will PM you; perhaps we can work something out if you can direct me.
Thanks again.
Thanks again.
Here ya go
http://www.cordite.pwp.blueyonder.co.uk/TF2103_1.pdf
apparently same same? Looks the same to me anyway!
Yes!
Only difference to mine is that my "power on" indicator is a small filament lamp actioned by a momentary-on push-button switch. That seems to have preceeded the Marconi then - no led. Otherwise the internal lay-out is exactly the same.
Thanks yet again; I shall now be able to sort matters out, also possibly replace transistors with newer types.
http://www.cordite.pwp.blueyonder.co.uk/TF2103_1.pdf is effectively the same machine. I have one too.
Hi Guys
link is now dead has anyone got a copy of this pdf i could download please??
I have an old unit that needs servicing.
Thanks in advance for any help
- Analogue Source
- Schematic: Venner TSA 625/2 signal generator
