Motor for turntable - Page 6 - diyAudio
Old 13th October 2013, 09:50 AM   #51
Send a message via MSN to sq225917 Send a message via Skype™ to sq225917
Stefano, as long as you run the motor at the recommended voltage you should have enough torque. When you begin to drop the voltage too far you will hear it struggle with the load as it kicks back and locks. My platter and sub-platter weigh 9lb and spin down from 33, with no belt attached, in about 5 seconds. So there's a fairly high MOI there.
Paradise Pre-reg PSU PCBs
Old 14th October 2013, 12:16 AM   #52
Stefanoo's Avatar
Ok..
What about the mat? Can you give me some more info?
Stefano
Old 14th October 2013, 01:55 PM   #53
Pm YNWOAN, he made it.
Old 14th October 2013, 06:41 PM   #54
Stefanoo's Avatar
sounds good! Thanks!
EDIT: Message just sent to YNWOAN!
Stefano
Old 16th October 2013, 04:14 PM   #55
Stefanoo's Avatar
sq,
what heatsink did you use on the controller board? does it get hot? Do I need one?
Stefano
Old 16th October 2013, 09:43 PM   #56
I used two small ones, about 70x40mm with 30mm deep fins. I think they dissipate about 10 watts each.
You could probably heatsink them to the case they don't really run very hot.
Old 9th November 2013, 02:56 PM   #57
meldano is offline meldano  Germany
Hi guys,
i translate the software for you:
Please contact me via PM with your email address and i will send the file!
Old 9th November 2013, 03:00 PM   #58
I use a modushop case as heatsink
Old 10th November 2013, 03:37 AM   #59
Are modusshop still in business? They don't answer emails.
Old 12th November 2013, 03:51 AM   #60
Stefanoo's Avatar
Originally Posted by meldano View Post
Hi guys,
Very nice!
Would you be so kind to send me the file at:
stefano_rumori@yahoo.it
Thanks!
Stefano
Three motor turntable ANALOGIST Analogue Source 37 22nd November 2014 05:58 PM
Turntable Motor davecooper Parts 0 21st October 2010 12:18 PM
Compact Disc Motor and Turntable - Advices for Replace and Motor Service wanted tiefbassuebertr Digital Source 5 2nd August 2010 09:19 AM
Help required for using a FDD motor as a turntable motor. binspaul Analogue Source 5 13th May 2009 03:59 AM
Motor for turntable. Tomek Analogue Source 33 9th October 2003 11:29 PM
Copyright 1999-2017 diyAudio
