Measuring for rumble
Old 29th October 2013, 02:58 PM   #31
kevinkr's Avatar
Last time I checked they did not have any available. Thanks for the heads up!
No option for shipping outside of Europe, and my Dutch is not very good frankly.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 31st October 2013, 09:18 AM   #32
tabarddn is offline tabarddn  New Zealand
Default Standard test
It would be good if we a DiyAudio could come up with a simple standard test for measuring rumble. The everyone could compare apples with apple.
tabarddn
Old 1st November 2013, 08:01 PM   #33
volken is offline volken  Netherlands
Not so simple you need a decoupled measurement table otherwise you measure ambient vibrations !
Volken
Old 1st November 2013, 11:15 PM   #34
user510 is offline user510
user510's Avatar
Volken
Yes. When I took possession of the Minus-K platform, I thought that the isolation it afforded would make it possible to attain valid points of reference for noise measurements.
-Steve
Old 4th November 2013, 10:05 PM   #35
radiosmuck is offline radiosmuck  Canada
radiosmuck's Avatar
Originally Posted by Barleywater View Post
Only valid measure of rumble is for that picked up by cartridge, thus platter must be in motion, and stylus in contact.
I remember a trick of building up a thickness of coins on the arm board and gently placing the cartridge onto the stack and turning on the motor.
Check the bass speaker cones, they could be flapping around producing watt draining subsonic bass.
Old 5th November 2013, 01:28 AM   #36
Barleywater is offline Barleywater  United States
When arm board is 400 pound block of granite this doesn't work so well. This is also basis for super heavy platters.
Old 5th November 2013, 11:20 AM   #37
radiosmuck's Avatar
What about those discs that contain rumble, many did?
It all seems too much work trying to convert a cement mixer.
Old 7th November 2013, 10:32 AM   #38
Default You do not need to go into rocket science
Yes there are many many variable, however if we at DIYAUDIO had a standard procedure then we could set up a bench mark.
However there is no standard procedure so we keep comparing oranges with apples.
tabarddn
Old 13th April 2015, 04:19 AM   #39
silent mike is offline silent mike  Canada
I know this is an old thread, but...
There are wireless vibrometers sold on ebay for as little as $100. They appear to work using reflected light... from a laser? I wonder if they could be sensitive enough to measured rumble off the spindle.
Old 13th April 2015, 06:02 AM   #40
Hiten is offline Hiten  India
Some recording software can generate 1kHz test tone. And also has facility to remove one waveform from other. So one can record 1kHz test tone from test LP and remove computer/software generated waveform from recorded test tone. What remains will be noise/rumble. I guess this will work. Wouldn't it ?
Regards.
Measuring for rumbleHide this!Advertise here!
Rumble filter LAJ Music 0 24th November 2010 05:08 PM
Turntable rumble? bereanbill Analogue Source 4 4th May 2009 08:57 PM
Rumble Filter soloxp Subwoofers 5 27th July 2006 12:02 PM
Passive Rumble filter? fortyquid Multi-Way 5 30th November 2003 12:25 AM
Turntable rumble lordvader Analogue Source 10 1st April 2002 11:26 AM
