Mini-Me phono preamp
Old 21st September 2013, 12:15 PM   #1
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Default Mini-Me phono preamp
Dear DIYaudio community,
I like to share this small design from me called Mini Me phono preamp. Last week I have completed the current version that I use.
It is a three part design with 6N16 miniature tubes. First part is a MC pre-preamp, second part is a MM impedance selector and the third part is the MM preamp with RIAA correction. I have designed a PCB that you can split if you do not need some parts. For the power supply there is also a PCB design.
Schematic
Looking at the schematic, the first triode(V1a) amplifies the signal 16x, after that R15,R24,R25 and C8 reduces the high tones according to the RIAA curve. The second triode(V1b) amplifies the signal also 16x, after that R10,R11 and C5 take care of the lower tones(bass) according to the RIAA curve. The third stage(V2a) just amplifies 16x, followed by a buffer stage(V2b). The total amplification factor is about 350x. That is 16x16x16x0.9 amplification for the tubes divided by 10 for the RIAA correction.
In front of the MM phonostage I like to use a impedance selector. This way I can easy optimize the loading for the MM cartridge. If you do not like to use it you need to use R1(47k) otherwise do not use R1.
The MC pre-preamp is an extra, it has a amplification factor of 9x. This stage I have not tested yet because I do not have a MC cartridge.
The power supply is pretty straight forward design. There is no noticeable hum or noise.
PCB design
download the PCB film files below,
http://www.monstercore.nl/6n16phono.pdf
http://www.monstercore.nl/6n16phonopower.pdf
RIAA correction
I did some measurements according the RIAA correction.
The specs of the MMstage
Amplication = 350x
RIAA curve = +/- 0,5db
SNR = -78db
THD+N = 0,135%
Channel separation = 47,3db
And with the MC pre,
Measurements with 100 Ohm at the input.
Amplication = 3000x
RiAA curve = +/- 0.5db
SNR = -77db
THD+N = 0.244%
Channel separation = 47db
I hope i have inspired some people to build this MM phono stage to.
Do not hesitate to ask me any questions.
Ronny
Last edited by Koifarm; 9th May 2015 at 07:18 PM. Reason: Changed distorsion data.
Old 21st September 2013, 06:17 PM   #2
kevinkr's Avatar
The unbypassed cathode resistor in the MC amp is a concern because you are amplifying all of the cathode resistor johnson noise. (Most MC have very low internal impedances so you will be adding a lot noise relative to the cartridge's noise floor.) An LED for bias could eliminate this as a concern.
I have used a variety of MC cartridges over the past few years such as the ZU DL-103, DL-103D, and currently own three different models of Ortofon SPU. I use transformers and active devices for step up, gains have ranged from 8V/V to 32V/V depending on MC and phono pre.. Currently I am using 16V/V (sut) and 21V/V (ss active) - you may need more gain. The popular DL-103 has an output of about 300uV @ 5cm/sec to give you an idea. (You did not mention the MM section's gain or I missed it, so 12X could be fine..)
The project looks great, please publish some specifications.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 21st September 2013, 07:02 PM   #3
Koifarm's Avatar
Thanks for your reply.
As i mentioned i still must test the MC stage. But already in the MM stage the 6N16 surprised me with no noise at all.
The MM stage amplifies 400 times, with the MC stage that is 4800 times so you get more then enough output voltage. ( 2V output with Ortofoon 2M red).
About MC stepup transformers i do not like them at all, they sound dull and liveless compared to some active setups i listened to in Germany and the Netherlands at audio meetings. Until yet i like the pacific MC pre with the 2sk170 with battery power as best.
In Oktober I have the possibillity to measure noise and distortion, but by just listening they are very low for a tube pre.
5 Oktober there is a Phono pre shootout from the people of www.zelfbouwaudio.nl, the Dutch version of DIY audio. the Mini-Me also enters that competition, i am very curious what other people will say about the Mini-Me.
Old 21st September 2013, 07:26 PM   #4
kevinkr's Avatar
I have had a lot of problems with suts myself, I find very low impedance MC will make fairly mediocre devices perform reasonably well. Higher impedances devices like the DL-103 imo are problematic with suts.
I use Lundahl LL1941in my main phono system (I currently have 2) and these are excellent with the SPU, but rather expensive.
I prefer a really good transformer to active, but I have found very few to like. I will say the amorphous core Lundahls are excellent. (LL1931/LL1941) Excellent HF extension, deep and well controlled bass, clean and very detailed presentation, balanced.
Will be looking forward to updates here, I'm sure the design will be well received.
Old 21st September 2013, 11:42 PM   #5
Hearinspace is offline Hearinspace  Canada
I agree. When I first tried Lundahls I went for the lower priced silicon steel cores, didn't care for the sound much and wrote them off as industrial transformers looking for sales in the audio market. Then for reasons I don't remember I was persuaded to try their amorphous cored transformers and was surprised at the difference.
Old 22nd September 2013, 12:45 AM   #6
kevinkr's Avatar
This is the real problem with audio, the good stuff is expensive and most people are not willing to take the risk that a real improvement is to be had if they spend all of this extra cash. It has worked rather well for me, but I am careful, and stick to stuff where I think there is real engineering content, not marketing hype.
Old 23rd September 2013, 06:05 PM   #7
Koifarm's Avatar
Today i did some measurements with a reverse RIAA circuit(+/-0.1db).
I like the results.
Old 23rd September 2013, 06:10 PM   #8
Koifarm's Avatar
The reverse RIAA circuit in used.
Old 23rd September 2013, 07:39 PM   #9
kevinkr's Avatar
Excellent result!
What is the tolerance of your reverse RIAA? My best one (commercial) is +/-0.1dB.
I'm too lazy to do this, but many audio test programs will allow you to run a generator sweep file with as many points as you can stand to calculate values for. (Probably write something for excel or the open office equivalent) This of course would remove the uncertainty of the reverse eq.
FWIW I've never thought it worth the trouble.
Old 24th September 2013, 08:37 AM   #10
Koifarm's Avatar
The reverse RIAA circuit is better then +/- 0,1 db. Beter then that i can not verify because my measure equipment is not better.
A lot of people use ARTA software with a good soundcard on the PC. They use then a inverse RIAA file.
Mini-Me phono preampHide this!Advertise here!
Phono Preamp PCB wanted - Transcendental Sound Grounded Grid Phono Preamp nathanjh13 Analogue Source 0 14th June 2012 10:19 AM
6112 and 6111 Mini-preamp TV7 Tubes / Valves 25 22nd December 2011 10:58 PM
FS: Mini headamp/preamp/buffer boards theAnonymous1 Swap Meet 1 26th November 2008 12:39 AM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
