Mini-Me phono preamp
Old 8th February 2018, 12:24 PM   #71
flancfuster is offline flancfuster  Romania
Hi everyone,
Here is my phono stage build. For MC amplification I used Lundahl transformers LL1941 and for MM part I used Mini Me schematic ( thanks Ronny for sharing it with us). It sounds awesome. I'm using it for my Thorens TD-309 TT with AT33sa cartridge. PCB was designed by a friend of mine and me and they were made in China.
"Without music, life would be a mistake." - Nietzsche
Old 8th February 2018, 06:08 PM   #72
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Great looking phono preamp.
Thank you for posting your experience with the Mini-me.
After building several different phono preamps, i also like the mini-me.
Ronny
Intergrated preamp with mini-me phono below.
Old 8th February 2018, 07:20 PM   #73
Ronny
Thank you Ronny,
One little thing I want to try, to use silver mica capacitors or polystyrene in RIAA circuit. What do you think?
Sorin
Old 8th February 2018, 08:32 PM   #74
Koifarm's Avatar
Polystyrene/styroflex(1%)are my favorites for riaa filtering, silvermica for cartridge loading.
Vishay mkp1839 i also use often in riaa filtering.
Old 9th February 2018, 03:52 AM   #75
lexx21 is offline lexx21  United States
Is there any chance of having the cad files available?
Old 9th February 2018, 07:14 AM   #76
Nice, I found polystyrene with the exact values at farnell, LCR is the maker. Do you have any experience with that? Any other recommendation on maker?
Sorin
Old 9th February 2018, 07:17 AM   #77
I can give you the gerber files. The design was made in Sprint Layout.
Old 9th February 2018, 09:49 AM   #78
Koifarm's Avatar
Yes, mine are with Designspark. This program is free. Just send PM with your emailadress.
Sorin
No experience with LCR. Just try and listen. I use a lot of n.o.s. Philips.
Not polystyrene but als very good is vishay mkp1839.
Old 21st March 2018, 08:37 PM   #79
I just replaced RIAA capacitors with polystyrene. Big differences in sound. They are LCR FX type from farnell.
Old 22nd March 2018, 07:48 PM   #80
Koifarm's Avatar
Normally there is no big difference between capacitors types or values are different. I hope you like the change in sound.
Mini-Me phono preampHide this!Advertise here!
Phono Preamp PCB wanted - Transcendental Sound Grounded Grid Phono Preamp nathanjh13 Analogue Source 0 14th June 2012 10:19 AM
6112 and 6111 Mini-preamp TV7 Tubes / Valves 25 22nd December 2011 10:58 PM
FS: Mini headamp/preamp/buffer boards theAnonymous1 Swap Meet 1 26th November 2008 12:39 AM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
