Mini-Me phono preamp
Old 24th September 2013, 09:56 AM   #11
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
I did some more measurements.
But i do not know with one is good according the noisefloor.
Graf 1 = -78db
Graf 2 = -97db
There is also a graf with harmonics.
2nd harmonic = -50db
3nd harmonic = -60db
Graf 1
Old 24th September 2013, 09:57 AM   #12
Koifarm's Avatar
Graf 2
Old 24th September 2013, 09:58 AM   #13
Koifarm's Avatar
Harmonics
Old 24th September 2013, 11:18 AM   #14
Koifarm's Avatar
Here the specs according to the measurements at the MM stage,
Amplication = 350x
RIAA curve = +/- 0,5db
SNR = -78db
THD+N = 0,0135%
Channel separation = 47,3db
Total cost for the project, about 100,-.
Next i will test the MC pre-pre.
Old 25th September 2013, 09:19 AM   #15
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I'm waiting your test the MC pre-pre.
Old 25th September 2013, 01:23 PM   #16
Koifarm's Avatar
Today i build one MC stage for testing purpose.
I discovered a fault in the PCB at the MC pre input, i shall correct that a.s.a.p.
I am very happy about the 6N16 tube. This tube has in the MC pre very little hiss, no humm, very little microphonics.
Here the specs i measured for the compleet Mini-Me with MC pre-pre.
Measurements with 100 Ohm at the input.
Amplication = 3000x
RiAA curve = +/- 0.5db
SNR = -77db
THD+N = 0.0244%
Channel separation = 47db
I did not use the Zener in the MC pre because there was no humm at all. I shall modify the schematic a.s.a.p.. For the heatersupply i used an extra LM7806.
I am very pleased
Old 25th September 2013, 04:40 PM   #17
Koifarm's Avatar
All schematic and PCB design are up to date ( As build).
Old 25th September 2013, 04:58 PM   #18
Where is the last MC schematic?
Old 25th September 2013, 05:11 PM   #19
Koifarm's Avatar
It is in the thread start, the first reply.
Just use the refresh button in your browser.
Ronny
Old 25th September 2013, 05:15 PM   #20
OK thank you Ronny.
Cheers
Felipe
Mini-Me phono preampHide this!Advertise here!
Phono Preamp PCB wanted - Transcendental Sound Grounded Grid Phono Preamp nathanjh13 Analogue Source 0 14th June 2012 10:19 AM
6112 and 6111 Mini-preamp TV7 Tubes / Valves 25 22nd December 2011 10:58 PM
FS: Mini headamp/preamp/buffer boards theAnonymous1 Swap Meet 1 26th November 2008 12:39 AM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
