Revamped Thorens TD 160. What else? - Page 2 - diyAudio
Old 20th September 2013, 05:08 AM   #11
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
Some folks seem to like cork mats, and they are DIY, so...
The TP16 is a nice tonearm, but sometimes the bearings get sloppy and worth adjusting. You could also consider replacing the arm. The wire in the TP16 is also very nice, and shielded, but some folks rewire them. When I installed RCA jacks on my TD-160 I also separated the tonearm ground wire from the RCA cable, and added a ground post.
If you have re-plinthed, damped the motor plate, and damped the sub-chassis, then you have done the big things. There are additional motor tweaks available, for example thrust bearing kits. I have heard of people "tuning" the RC network feeding the motor, and getting reduced noise spectra as a result.
Beautiful job, especially that plinth.
Old 20th September 2013, 05:14 AM   #12
nezbleu's Avatar
Oh, here are a couple of ideas. I removed the speed change mechanism from my Thorens, I seldom play 45's, can always move the belt manually, and it just seemed like a possible source of vibration.
Also, and I'm not sure I recommend this, but it seemed to me that the top trim plate was buzzing on the motor plate. I removed it. It had been glued down, but there were a lot of voids. I cleaned up the old glue, then glued it down again with silicone adhesive spread very evenly. To remove it, the old glue responded well to heat, then I cleaned it up with acetone. I have heard that some TD-160's have the top trim plate anchored with double-sided tape, so YMMV.
Old 20th September 2013, 08:11 AM   #13
Originally Posted by kevinkr View Post
Never seen anything but single stage polishing kits around here. You must have a great hardware store in your neighborhood.
My hardware shop is online! Click the image to open in full size.
Old 20th September 2013, 08:17 AM   #14
Thanks for the feedback. Just a question, what do you mean by "trim plate" ? The entire top plate ?
Old 20th September 2013, 08:26 AM   #15
Like this Dutch company does: Thorens TD160 HAT Motorkit
Old 22nd September 2013, 04:47 AM   #16
nezbleu's Avatar
No, the top plate consists of the steel plate, and a thin trim part glued to it. It's the nice looking part, as opposed to galvanized steel.
Old 22nd September 2013, 04:48 AM   #17
nezbleu's Avatar
Exactly. Some folks have DIY'ed the same thing.
Old 22nd September 2013, 06:44 AM   #18
Do you have a link to this, please?
Old 22nd September 2013, 07:40 PM   #19
kevinkr's Avatar
ffivaz I tried your link today, it didn't work for me.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 22nd September 2013, 08:28 PM   #20
jan.didden's Avatar
Originally Posted by volken View Post
Here you can see a upgraded TD160 against his older model the TD124 on the X-Fi show last weekend
Hanze HiFi no doubt
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 12 is out! Check out my Autoranger and SilentSwitcher
Thorens TD 160 Super - anybody else use one? Gretsch6136 Analogue Source 25 29th October 2014 10:10 AM
Thorens TD 160 tonearm mrdeltoid Analogue Source 0 9th September 2011 06:55 PM
Thorens TD-160 Skipping Kofi Annan Analogue Source 25 8th November 2004 08:32 AM
thorens td 160 replacement motor dionysio Analogue Source 2 31st March 2004 04:45 AM
Finished modifying Thorens TD 160! Jerry T. Analogue Source 42 30th March 2004 01:41 PM
Copyright 1999-2017 diyAudio
