Revamped Thorens TD 160. What else?
Old 18th September 2013, 08:07 PM   #1
ffivaz is offline ffivaz
Default Revamped Thorens TD 160. What else?
I bought an old mk1 Thorens TD 160 for a few bucks some time ago on a swiss ebay-like site. It came with a well working motor. I applied some cork matte under the top (motor) plate and the arm and platter plate. I built a new case from bamboo, put some RCA outputs and polished the platter. It sounds beautiful with my Denon a Denon DL 110. The arm is the original TP 16. I did not dismount it or change the cables.
What else would you propose? Especialy, what would you propose as a replacement for the original mat?
Here are some pics.
Old 19th September 2013, 04:13 PM   #2
lexx21 is offline lexx21  United States
I would leave it as is. I have the td150 (same mat,etc..) and it sounds great.
Old 19th September 2013, 04:48 PM   #3
R.I.P.
Hi, Kabusa sell nice Technics SL1200 mats, rgds, sreten.
Old 19th September 2013, 04:48 PM   #4
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Is there inside it some class of preamplifier, equalizer or some electronics, or signal at the RCA as the gets from the cartridge?
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 19th September 2013, 06:53 PM   #5
I have a Bottlehead Reduction as a outside preamp... The signal out of the RCAs is directly taken from the cart.
If I have to put a Technics mat on a Thorens, I'll choose this one : Voodoo Rhythm Records — Slip-Mat Voodoo Rhythm Skul Logo!
Old 19th September 2013, 06:59 PM   #6
lcsaszar is offline lcsaszar  Hungary
I use black felt mat on my TD-160 (Mk II). How did you polish the platter edge? How do you avoid gathering dust?
Old 19th September 2013, 07:32 PM   #7
volken is offline volken  Netherlands
Here are some pics.
Here you can see a upgraded TD160 against his older model the TD124 on the X-Fi show last weekend
Old 19th September 2013, 07:48 PM   #8
R.I.P.
The Technics 7oz and 17oz rubber mats are the only decent ones I know.
Neither are as good as my ancient hard rubber Disk SE2.2, 1kg, 2.2 lb, 35 oz's.
rgds, sreten.
I've been round the houses trying every sort of mat. IMO rubber is best.
Old 19th September 2013, 10:30 PM   #9
I used a three-stages "usual" polishing kit you'll easily find at your local hardware shop.
I avoid dust by using it, and cleaning it sometimes
Old 20th September 2013, 03:53 AM   #10
kevinkr's Avatar
<snip>
Never seen anything but single stage polishing kits around here. You must have a great hardware store in your neighborhood.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Revamped Thorens TD 160. What else?Hide this!Advertise here!
Thorens TD 160 Super - anybody else use one? Gretsch6136 Analogue Source 25 29th October 2014 10:10 AM
Thorens TD 160 tonearm mrdeltoid Analogue Source 0 9th September 2011 06:55 PM
Thorens TD-160 Skipping Kofi Annan Analogue Source 25 8th November 2004 08:32 AM
thorens td 160 replacement motor dionysio Analogue Source 2 31st March 2004 04:45 AM
Finished modifying Thorens TD 160! Jerry T. Analogue Source 42 30th March 2004 01:41 PM
Copyright ©1999-2017 diyAudio
