TTPSU Output stage
TTPSU Output stage
Old 18th September 2013, 05:47 PM   #1
cygnus x1 is offline cygnus x1  United States
Default TTPSU Output stage
I was looking for a simple (IC) output stage to use with the Norre TTPSU, rather than use a step up transformer for a 120 VAC motor. Or maybe the as designed output stage could be redesigned for 120V? I was also thinking of a op-amp stage driven off the feedback loop to come up with the 90 degree out of phase signal and a second output stage, rather than just a capacitor to drive the motor. Just looking for something simple to try. Anyone willing to give this a go?
Old 19th September 2013, 06:20 PM   #2
I found I had two LM3886 sitting in the parts bin, that takes care of the amp sections, now just for the op amp phase converter.
TTPSU Output stageHide this!Advertise here!
Someone with experience with TTPSU Thesoundmen Analogue Source 7 4th March 2016 02:31 PM
Common emitter stage driving low hfe output stage Fusion916 Solid State 1 20th December 2012 05:05 PM
Turn on pre driver stage first or output stage first?? Leolabs Solid State 1 6th December 2011 11:28 AM
Help with input stage driver for EL84 output stage AudioGeek Tubes / Valves 2 20th March 2010 01:38 AM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
