DIY Rega TT PSU needed - diyAudio
Old 5th August 2013, 12:00 PM   #1
Default DIY Rega TT PSU needed
Hi analoge friends,im searching for an Rega DIY TT PSU 24V. Have anyone an schematic for me and can help out? The turntable is a Rega P3 with a 24V DC motor. The problem is, that the platter speed is to fast. I measured +0,5 % to fast. RegardsChris
Old 5th August 2013, 06:30 PM   #2
Send a message via MSN to sq225917
Roehren-und-Hoeren :: Thema anzeigen - Luxusnetzteil fr Synchronmotoren mal anders
Google translate is your friend. The best Ac psu controller on the market- bar none.
hoping to pick up some things.
Old 6th August 2013, 04:58 AM   #3
analog_sa's Avatar
I've seen it before but couldn't quite figure out if it was commercial or diy. Is the source code for this available?
Old 9th August 2013, 09:18 PM   #4
Daniel, (Meldano) provides pcb's and chip already programmed. I doubt he is giving the source code away. I believe the design is used by TW on their Ac decks.
TT from Rega bearing and motor Sella Analogue Source 14 16th February 2011 02:18 PM
Rega Planar 3 PSU resistor kimmo Analogue Source 8 3rd March 2008 11:23 AM
Which cartridge suitable for Rega P3/25 TT? henkel Analogue Source 7 8th April 2006 03:20 PM
Which TT do I use as a donor for DIY TT? G Analogue Source 1 13th September 2004 04:43 AM
Has anyone tried these Rega/Linn TT 'upgrade kits'? Saurav Analogue Source 2 30th January 2004 05:58 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
