$3.00 Phono Bearing - diyAudio
Old 17th July 2013, 03:13 AM   #1
mlise is offline mlise  United States
Default $3.00 Phono Bearing
A first experimental phono spindle bearing. I'm totally pleased with the results. This is just junk from the hardware store, but fine for prototyping. A final version would be tool steel, hardened after the divot is banged in, and a silicon nitride ball.
The divot is from a 5/32" ball bearing, and the pivot is a 1/8" ball glued in the end of a set screw. I'll put a ring of polyethylene or lignum vitae or something for the bearing at the bottom. With a gentle nudge it spins for several minutes. You can see the breeze blowing it around in the video.
$3.00 Phono Bearing Experiment - YouTube
Need to change phono gain on Rowland phono module Mikelo Solid State 0 4th October 2009 01:43 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
spindle bearing bob38138 Analogue Source 9 29th March 2008 01:11 AM
For Sale: Ceramic 9 pin tube sockets $1.00 each 12 for $10.00 Sal Brisindi Swap Meet 0 26th June 2007 10:45 PM
18w8531g-00 vs. 18w8545-00 ermes Multi-Way 1 18th April 2004 05:05 AM
Copyright 1999-2017 diyAudio
