Another Technics SL-1200 mkll turntable mod
Old 11th July 2013, 11:20 PM   #1
audiostar is offline audiostar  United States
Default Another Technics SL-1200 mkll turntable mod
Index This is a wonderful mod.
Old 11th July 2013, 11:36 PM   #2
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
There's some interesting stuff there, thanks for posting.
jeff
Old 11th July 2013, 11:43 PM   #3
I think this mod is from member Qwin.
Old 12th July 2013, 03:49 PM   #4
6L6 is offline 6L6  United States
6L6's Avatar
His SL-1200 modifications are nothing short of amazing. It's really closer to "Building a new turntable using a Technics motor."
I'm currently corresponding with him about this mod - Technics SL-1200 DC Power Supply
Old 30th December 2014, 11:52 PM   #5
Voicecoil is offline Voicecoil  Canada
I thought I went overboard with my 1200.
The JKWynn is unbelievable.
Old 31st December 2014, 01:08 AM   #6
What are you cooking? wow, very nice. more pictures please. details. What did you do to the turntable?
Old 31st December 2014, 02:20 AM   #7
Thanks audiostar.
This was my progression:
Started modding a very clean stock 1200. Added strobe disabler, dc rectifier and sorbothane feet from KAB. Also tonearm rewire and damping.
Then got a great deal on a Nottingham Interspace SE (seen in background).
1200 sat idle for a very long time.
Then a Clearaudio Stradivari cartridge came my way and I picked up a 12" Nottingham arm and built an arm pod for it.
Next I started plotting a complete custom build starting with a VPI Classic platter and bearing.
Seeing all my spare parts together, I got the crazy idea to sit and center the VPI platter on the 1200 platter (cork/rubber mat between), turn the 12" Nottingham arm to the proper spindle to pivot distance and voila!
I was actually shocked to hear how incredible it sounds.
I've only lived with it for a few weeks and I'm a little concerned that the Technics bearing can't handle the weight.
Bearing upgrade may be the next step.
Old 31st December 2014, 07:43 PM   #8
Voicecoil,
Are you considering the Mike New bearing? An effective upgrade is an external power supply offered by many. I am sure you can't go wrong with one by davefl from
Landfall Systems. The details are in the thread Technics SL1200 internal brackets, regulator and external power supply.
Old 31st December 2014, 07:47 PM   #9
Tattoo is offline Tattoo
Tattoo's Avatar
The first thing I would change on a SP1200 is the arm. A nice SME with a good cartridge on the SP1200 is hard to beat.
If you search for X, than eventually you'll find X. Hopefully X is the truth.
Old 1st January 2015, 06:18 PM   #10
Definitely considering the Mike New bearing. A little expensive though.
I may try to mod/upgrade the stock bearing. Many seem to have had success with that.
I mostly agree with Tattoo that the stock 1200 arm is the weakest link.
The arm tube stinks. Very thin and resonant. Stock tonearm wire/pcb are nothing special either.
The arm bearing system is IMO very good. Damping the armtube and a rewire will yield noticeable improvements (and increase arm mass so check cart compliance).
You can also go the Funk Firm route and change the armtube completely.
...or replace the tonearm. I like the Jelco 750d on the 1200.
Next biggest improvement I found was damping the "ringy" platter with platter mats. I found the copper and aluminum ones best, then rigid graphite composite. Even 1/4" thick cork was very good.
Another Technics SL-1200 mkll turntable modHide this!Advertise here!
FS: Technics turntable SL-1200 mkII Thomas Giz Swap Meet 2 29th January 2013 04:40 AM
Technics SL-1200 Speed Issue Loren42 Analogue Source 14 12th August 2010 07:18 AM
Technics Sl 1200 bearing nimbus24 Analogue Source 10 22nd July 2009 12:27 PM
only right sound from my Technics SL-1200 kollisionseb Analogue Source 3 12th February 2009 11:59 AM
Technics SL-P 1200 NoBit Digital Source 0 18th April 2008 12:28 PM
Copyright ©1999-2017 diyAudio
