Technics SL-1200 DC Power Supply
Old 10th July 2013, 04:35 PM   #11
PKI is online now PKI  United States
PKI's Avatar
I just found this tread, nice job! I am a huge fan of 1200, its is so irrational, but it is maybe one of my fav tables of all times :-)
Old 10th July 2013, 05:20 PM   #12
6L6 is offline 6L6  United States
6L6's Avatar
There is nothing irrational about liking a turntable that was made for audiophiles at the height of the LP era.
Old 11th July 2013, 12:07 AM   #13
6L6's Avatar
Originally Posted by Khom View Post
I changed power regulator to classical LM317 circuit as a first step of PSU upgrade, it very simple and took 1 hour.
Khom - Do you by chance have any more photos or a sketch of your perfboard layout you used for the 317 circuit? I would love to make one just like that.
Old 11th July 2013, 12:27 AM   #14
buzzforb is offline buzzforb  United States
buzzforb's Avatar
6L6,
Check out the K-multiplier on the forum. I have read that with LM317 in front it is quite nice.
...Shape the sound , Man!
Old 13th July 2013, 09:02 AM   #15
Khom is offline Khom  Belarus
Yes, of course. See attached photos:
1. Schematic. It's simple datasheet schematic calculated to 20V output DC.
2. and 3. Top and bottom of board, all connections made by parts leads and some additional wires. I didn't created printed board. To connect you can use old YELLOW and ORANGE wires (J1 and J3 - see original schematic 4.), ground wire (BLACK on my pictures) should be added and connected into Tech PCB in any suitable place near power regilator. Do not forget to isolate LM317 from chassis (I used thin mica strip)!
However I still think that the best power solution for Technics is combine of an external PSU with transformer and improved internal regulator like this or something similar.
Old 3rd August 2013, 04:25 AM   #16
6L6's Avatar
Kohm - Thank you for the photos! I'm only now just seeing them, I wish I would have checked back sooner.
Mine was done point to point and is not very pretty. (Hence the liberal use of heatshrink...)
See the top post for new photos.
Old 3rd August 2013, 07:36 PM   #17
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
great ( both tutorials )
I done something similar some 15 years ago , with my (then ) best turntable SL1400 (that one with all things digital and buttons)
after , it was double heavy , even with xformer removed
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 9th October 2013, 02:42 PM   #18
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
I just found that thread...
It will be tested very shortly
Too many projects... so little time...
Old 9th October 2013, 02:55 PM   #19
6L6's Avatar
Great!
There is lots more activity on this thread at Art of Sound, a few people have already done this mod with great results --
SL-1200 DC Power Supply DIY
And if you are interested in more mods to the Technics, I was astounded at how much difference changing the tonearm wires made (I am not a cable guy, but this is incredible...) --
Rewiring SL-1200 Tonearm
Old 9th October 2013, 03:29 PM   #20
dimkasta's Avatar
Yep I have changed my cabling to single run from cartridge to RCA with cardas litz about 2 years ago and never looked back.
But these days I am flirting with the idea of trying a medical grade twinax silver cable I am currently using as interconnect with excellent results...
Edit: I just checked your other thread.
Advice for your next step in wiring. Lose the pcb and run a single run of litz from the headshell to the RCAs. And if you use only one cartridge, I would also advise removing the pins from the arm's end and headshell so that there are nice holes there, and run a single run from cartridge to the RCAs.
Technics SL-1200 DC Power SupplyHide this!Advertise here!
Technics SL-1200 Speed Issue Loren42 Analogue Source 14 12th August 2010 06:18 AM
Technics Sl 1200 bearing nimbus24 Analogue Source 10 22nd July 2009 11:27 AM
only right sound from my Technics SL-1200 kollisionseb Analogue Source 3 12th February 2009 10:59 AM
Technics SL-P 1200 NoBit Digital Source 0 18th April 2008 11:28 AM
technics SL 1200 MK3D tonearms flip Analogue Source 4 6th September 2007 01:43 PM
