DIY linear tonearm - Page 101 - diyAudio
Old 31st October 2013, 04:15 AM   #1001
kffern is offline kffern  Australia
Send a message via Skype™ to kffern
Apologies if I don't respond to all the suggestions. i'll try to later.
I fitted the new bearings and it still wouldnt track. Removed the moouse wire leads and it tracks fine. There is a problem with the new bearings though (as they are metal sealed) if I don't fit the spacers correctly (6mm brass standoff i use) it can bind the bearings.
Put the original bearings back on and it looks like it tracks well if I hold the wires directly over the carriage. No point in messsing about with a better cable stay as I will get new wire soon. It will have to be movable from the look of it.
After all the messing with the carriage the mouse wire is a bit kinked and very hard to get it to loop up and onto the cable stay like it did when new.
cats squirrel, I used isopropyl alcohol to clean the bearings.
I'm not a fan of WD40. Its damages plastic and rubber I think and I don't want residue all over the turntable.
Straight tracker, The tilting of the arm was a last resort. I normally have it straight. What was it, that it didn't do well? It occassionally stuck in a groove, but I now put it down to the wire.
Kffern
Old 31st October 2013, 04:19 AM   #1002
vynuhl.addict's Avatar
I was always of the understanding to never touch the clearaudio/souther bearings with any cleaner, especially alcohol?.
Colin
Old 31st October 2013, 07:14 AM   #1003
bgruhn is offline bgruhn  United States
Colin
I use isopropyl alcohol for cuts and bruises and bee stings and killing germs etc. As an industrial cleaner it doesn't cut the mustard or the grease and oil.
BillG
Old 31st October 2013, 07:21 AM   #1004
Straight tracker, The tilting of the arm was a last resort. I normally have it straight. What was it, that it didn't do well? It occasionally stuck in a groove, but I now put it down to the wire.
Kffern
Good for you! I'm glad you are resolving the problem. I went with #36 copper magnet wire loosely twisted. Seems to work just fine.
Old 31st October 2013, 11:18 AM   #1005
Clearaudio 33awg is affordable and works well, unfortunately much wire has memory, we don't want this. We must either go thin in magnet wire with little resistance or a wire such as litz that has less tendency to bounce back, mouse wire is too thick and rigid as I've noticed, maybe good for pivoted arms but not here.
Colin
Old 31st October 2013, 12:03 PM   #1006
Have a look at this:
HF-Draht+Litze
Hans.
Old 31st October 2013, 01:10 PM   #1007
I'm trying not to labour the point, but even if you don't like WD40, for whatever reason, it is useful in displacing water, so this is for others who have potential problems with bearings.
If water gets into the bearings, from whatever source (remnants from alcohols) it must be flushed out with WD40. This can then be flushed out with a light oil. AFAIK, propanol (IPA) and light oil are not miscible, so if found in the bearing, will cause problems, this assumes the bearings are not sealed!
Most bearings will need running in (breaking in?), which means lubricating, and fixing in a drill and spun at high revs, so that any lube inside the bearing can do its job. Think of it as the same as breaking in a new 'speaker, amplifier, or component. This would seem very important in this situation, where stiction would seem to be the biggest 'show-stopper'.
forward through scholarship, not bullship
Old 31st October 2013, 02:50 PM   #1008
tvi is offline tvi  Australia
tvi's Avatar
Tetrachloroethylene
brakeclean
Might be better to degrease with
The small part of ignorance that we arrange and classify we give the name of knowledge.
Ambrose Bierce
Old 31st October 2013, 04:27 PM   #1009
quote: Might be better to degrease with
as it is a CFC, (or equivalent), it will be night impossible to buy in the UK, although old fashioned dry cleaners may provide a little, BUT, it is not miscible with water, so concerns still apply in using alcohols for pre-cleaning.
Old 31st October 2013, 08:02 PM   #1010
DIY linear tonearm
The ony changes since this picture are the 12 mm glass rod and changed to 6mm spacers from 5 mm spacers(cut down 6mm brass unthreaded standoffs)
Again, I played a number of LPs with both configurations until I attempted the polishing.
No sign of the replacement bearings as yet so maybe another day before I do anything.
kffern
Can you check out my idea, can you test it..
If you ad two small pulley with thread and some weight on the end just to help the head shell to track better.
I think is good idea if you mount the two pulley the right place and pick the right weight just to ad some help.
Greetings G
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 5 31st May 2015 03:55 AM
Another DIY Tonearm johnmarkp Analogue Source 0 21st April 2008 11:07 PM
my DIY Turntables and DIY tonearm Roger Waters Analogue Source 57 22nd January 2008 06:05 PM
Magnetic suspension linear-tracking tonearm? Shaun Analogue Source 5 4th June 2003 10:21 PM
Copyright 1999-2017 diyAudio
