Okay,
I understand how you would use a tank to smooth the pressure pulses and understand how that would work. On the magnetic side I also see how that could be used in an attraction method and this seems like a simpler solution with no mechanical pumps or anything besides a passive set of magnets. I too look forward to your design MiiB, I think I could design such a system in Solidworks but I will wait and see what you give us.
Steven
Steven
David,
Nice work and examples there. It does appear to be 0.018" depth from your picture though. What is the zerk fitting used for, grease? Most of the old pumps I remember where fairly quite, at least the old Silent Giant pumps that I remember but it would seem that you would have to make sure that the pump was running before the platter could spin or that it was stopped before the pump was turned off or you would have contact of the surfaces?
Hi David,
Congrats for your tech skills (& several/many air test) and air bearing TT.
Karel
I would like to discuss the issue of the motor.
I have an Amazon DC motor that is fed by batteries. that is the most simple solution but maybe not optimum. I think a motor with more torc is better.
I have called Sperling today and await a reply.
On another forum the Revox B77 capstan motor was recommended.
Here an offer on Ebay :
REVOX B77 MKI "CAPSTAN MOTOR 9,5/19" 1978-1980 TON-MOTOR **TOP** | eBay
Joachim,
Don't even suggest that I cut into my Revox, not for the motor, there have to be easily available equivalent electrical motors. Do you know the specifications on the motor, like torque and horsepower and rpm ratings and such. AC or DC. I haven't looked inside my tape machine for so long, I do remember the tape drive motors which were large. I don't remember the capstan motor?
My Spiral Groove SG1 has a Premotec.
It has a heavy platter too and sounds fantastic.
Very close to master tape.
Yes, premotec is used also by linn and my RD80 also has one. Quite good and not too expensive if you choose the country you are buying it from.
- Analogue Source
- The Good Turntable
