The Good Turntable - Page 2 - diyAudio
Old 6th June 2013, 02:24 PM   #11
Joachim Gerhard's Avatar
Here is a way to make a tangential tonearm :
Tonarm
Old 6th June 2013, 03:03 PM   #12
Kindhornman's Avatar
Joachim,
With the complexity of that mechanism, looks like a parallelogram, what is the advantage of that over a linear tracking system? I didn't convert that to English but I see the concept. What was the problem with the linear tracking systems such as on the Thorens turntables that I always thought looked like they took care of the inner to outer groove alignment situation?
Old 6th June 2013, 03:58 PM   #13
PTFE/PE Bearings seem to be a bad idea .
I thought about it for my next Turntableproject and talked about it wiht an mechanic engineer who works with this every day .
He told me it would not be longtimestable .
Some time later i met Thomas Woschnik and he also says its not a good idea .
He showed me an TT he made in early years wiht a Teflonbearing .
It wobbles like an dogtail soon after few month .
There are better materials for turntablebearings .
greatings , Dirk
Old 6th June 2013, 04:47 PM   #14
Here is a picture of the ptototype tonearm .....
Old 6th June 2013, 04:48 PM   #15
I am not the designer of the bearing so Dominik should answer.
Old 6th June 2013, 04:56 PM   #16
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Is it a blackened golf-ball?
Old 6th June 2013, 05:41 PM   #17
directdriver's Avatar
Originally Posted by Joachim Gerhard View Post
Here is a way to make a tangential tonearm : Tonarm
This genre of tonearms is covered more extensively in my thread, if you're interested in reading. What is interesting and what I like about this articulated pivot arm is that the bearings consist of TWO unipivots at the base, with magnetic stabilizing. Pretty cool. But the headshell bearings are gimbal type are similar to the ones on the RS Lab tonearm which I think could be simpler by using good quality old fashion ball bearings.
Old 6th June 2013, 05:53 PM   #18
Thanks for the links.
Be Yamamura made an arm like that a long time ago :
Google-Ergebnis für http://www.thefunkyway.com/gearmus/djgear/decks/Yamamura%20Churchill%20J%20turntable.jpg
Old 6th June 2013, 06:46 PM   #19
I guess I will have a lot of reading to do to catch up on the differing design elements. What is the basic difference between a straight arm as shown and the S bent arms? I assume it must be a resonant difference or something of the sort.
Steven
Old 6th June 2013, 07:13 PM   #20
I think an S bend was the easy way to angle the headshell.
No modern high performance arm has an s shape any more.
You can make a straight arm stiff enough without resonances in the audible band.
I will show you an example in the next post.
The electronically controlled AEG G 020 motor - is it good for a DIY turntable? waretweaker Analogue Source 10 8th July 2015 10:01 PM
a good second hand turntable for teenager jives11 Analogue Source 14 24th October 2011 07:15 PM
1200 turntable (any good?) R. McAnally Analogue Source 28 1st October 2002 08:02 PM
which turntable is good for parts ? promitheus Analogue Source 4 8th July 2002 11:18 AM
Copyright ©1999-2017 diyAudio
