| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hello!
I have a Philips FP146 turntable from the '90s! Yesterday I tried to use it after at least a decade. It didn't work. I opened it and I realized that its AC adapter is not working properly. The name and serial key of its adapter is: AMC 8549 3111 158 30050 Is there any possibility that I can find its technical info in order to replace it with a new one? The only informations I can find about on the turntables are: 220V, 50Hz, 14W Thanks in advance!
#2 |
Somewhere on the adapter it should (I would have thought) give the voltage and whether its AC or DC output. The 3111 bit sounds like a Philips part number.
Maybe close up pictures would help. Are you sure the adapter is faulty ? Maybe a cable break or problem with the connector. Getting a new adapter should be easy as long as we know the voltage, the polarity and whether its AC or DC. If you don't get much response I can move this over to "power supplies" forum.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
Thanks for all of your help Mooly!
I'll post some photos in about an hour because I have a job to do in the next our! |
#4 |
No problem... I'll be around later if no one else jumps in.
#5 |
The last one is from the turntable.
#6 |
I was thinking of a little "wall wart" when you said adapter.
That's a simple mains transformer with one secondary. Is it open circuit on the mains input side ? Many have a thermal fuse embedded in the windings. Check the winding on a meter on ohms range, It should read low resistance across the mains input side.
#7 |
More info... if you look where the secondary connects in the TT you will find either a single diode rectifier or a bridge rectifier. Close to this will be a "large" electrolytic capacitor. If you look at the voltage rating of the cap we can work backwards to deduce a reasonable ball park figure for the transformer voltage.
If the thermal fuse is open circuit then there is always the possibility that a fault (such as a shorted rectifier etc has caused the tranny to overheat. It may or may not be just a faulty transformer.
#8 |
You can download the service manual at:
70FP146 Service manual The transformer feeds a very simple power supply consisting of a bridge rectifier and reservoir capacitor. Output voltages are an unregulated 15VDC and 8VDC regulated via a voltage regulator IC. So any transformer giving approx. 15VDC after rectification will do. Rundmaus |
#9 |
That should help... thanks.
#10 |
Thanks for your help!! =)
Can u suggest me a transformer to buy from amazon.co.uk or ebay.co.uk? I don't want to buy a new one which won't work! Thanks again! =) |
| 12V AC adapter to 5V | BubbaGump | Power Supplies | 5 | 28th October 2010 06:26 PM |
| Pin polarity for T-amp AC adapter? | Raoul | Class D | 4 | 24th August 2005 03:32 AM |
| ac adapter for 12v trigger | cbecker33 | Parts | 0 | 15th January 2005 05:45 AM |
