| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
would a tonearm become a variable mass tonearm if one were to cut a slot in an arm tube and fit a weight inside the arm tube with a bolt holding it in position so one could slide the weight up and down the arm tube?
my reckoning is that sliding the weight up towards the yoke would allow for heavier cartridges while sliding it towards the headshell would allow for lighter cartridges. or am I being stupid again.. lol |
#2 |
Not sure what you are trying to achieve?
If you want to vary the effective mass of the tonearm, put some blutac on top of the headshell. Vary the amount of blutac to suit. |
#3 |
The SME series III allowed for variable mass by adding, or subtracting, lead weights in the counter weight. They were added to the front of the assembly, with the remaining space in the counter weight assembly filled by 'hollow' plastic spacers.
So, I'd say you aren't being stupid at all, just perhaps didn't have the best way to do it. |
#4 |
Never think of yourself as being stupid!
Soundsmith provides a set of cartridge mounting thumb screw pairs, (no screw driver required) that are progressively heavier. They are made from Delrin, aluminum, stainless steel and brass. I think they know what they're doing. Sincerely, Ralf |
#5 |
ok further to my silly idea. how about the same weight but used as the VTF. so you would attach the cartridge then balance the arm with the sliding arm tube weight at the back of the arm but use the stub weight to balance. once balanced then slide the arm tube weight to desired VTF. that way the armtube would always be the correct mass for the cartridge.
i suppose working out the correct weight for the internal balance weight would be the headache. |
#6 |
Mayware Formula 4 arms had a sliding weight which made the equivalent mass adjustable. Hit images.google.com and you'll see how they did it.
| What is effective mass of Versa Dynamics 1.2 tonearm | D10 | Analogue Source | 17 | 5th February 2013 10:16 PM |
| Sansui SR-222 tonearm eff. mass?? | dukasound | Analogue Source | 3 | 12th August 2009 08:10 PM |
| Effective Mass of a SL1210 tonearm | Netlist | Analogue Source | 3 | 4th May 2008 09:26 AM |
| Linear tracking tonearm vs. Pivoting tonearm | Don Nebel | Analogue Source | 1 | 4th November 2007 10:49 PM |
| BIC 960 tonearm eff.mass | percy | Analogue Source | 8 | 8th August 2006 10:12 PM |
