MC step-up transformer - Page 3 - diyAudio
Old 9th May 2013, 12:19 PM   #21
Banned
Maybe 100windings primary and a little less step-up 1:10 so 1000 secondairy.
In between each primary you wind 10 secondairy
Originally Posted by EUVL View Post
The Denon DL-103R has an impedance of 14 ohm.
Would your above example be suitable in post #11 ?
What would be the typical leakage inductance be ?
Should a shield be put on the outside ?
I am total idiot with transformers, so apologies for stupid questions.
Patrick
Old 9th May 2013, 12:19 PM   #22
merlin el mago's Avatar
Originally Posted by guglielmope View Post
Very interesting!
And how about the type of wire?
Ciao
Guglielmo
Originally Posted by merlin el mago View Post
wire type?
Old 9th May 2013, 12:27 PM   #23
EUVL is offline EUVL  Europe
> In between each primary you wind 10 secondary
Sort of like bifilar (1 turn primary next to 10 turn secondary, all on the same one single layer) ?
Thanks again,
Patrick
xen-audio.com
Old 9th May 2013, 03:31 PM   #24
Banned
All on a single layer and primary between 0,5 and 1,0mm (depends on how many turns is need on 1 layer)
Secondary 0,15mm - 0,20mm.
All wires can be normal transformer wire (I used for the primary a teflon isolated wire but would not do that a second time)
Old 9th May 2013, 08:57 PM   #25
GazzaFloyd's Avatar
Originally Posted by esltransformer View Post
The right material Metglas magnaperm 2714AF
http://www.manz-electronic.com/downl...212708f721b788
or you can use from Vacuumschmelze the 6025F (=the same as 2714AF)
This firm sells it:
MES Manz Electronic Systeme OHG | Softmagnetic products | Semiconductors | Busbars | Military and Space | Heat sinks
or the 6025F:
Online Catalog & Consulting
I used the 2714AF (MP3210P4AF) 40 primary windings and 600 secondary windings
This looks like a great option.
But what size are the two wire types?
How long did it take to wind? Given the tiny size of these cores.
Is this the same principle as these insanley priced Stepups if so even given the labour costs if indeed the are hand made.
This is looking like a great discusion.
Garry
Old 10th May 2013, 06:46 AM   #26
Banned
Garry
I used secondary normal magnet wire. The primary wire is a teflon insulated wire but instead of that you can use a normal magnet wire too.
Yes, most insanely price step-up transformers from "high end" manufactures are the same as this transformer I made or even worse.
I know for sure that Tribute used this core in the past (maybe now Tribute uses the vitrovac 500F but that core is less good but has a higher Al-value because it's even bigger)
Old 10th May 2013, 08:49 AM   #27
GazzaFloyd's Avatar
thanks esltransformer
What about the time to do the build?
I sit in front of the TV watching sport 4-5 hours a week other wise doing very little, this may keep me busy over the winter
Old 10th May 2013, 10:39 AM   #28
The pic shows first wired the secondary with magnet wire and after the primary with teflon, is OK?
Old 10th May 2013, 10:41 AM   #29
@esltransfomrer
YHPM
Old 10th May 2013, 10:59 AM   #30
Banned
NO
I do first the primary wire and then in between the secondary
Just for the record: I can make mc transformers for everybody but i have to do it by hand. That is way to expensive so I advice everybody to wind their own mc transformer.
Ferrite core transformer design step by step Aucosticraft Power Supplies 159 20th June 2015 02:20 PM
Choose proper load resistance for MC step-up transformer rongon Analogue Source 21 15th February 2014 10:26 AM
nuvistor MC step up reinhard Tubes / Valves 66 14th February 2014 01:27 PM
Step-up MC transformer for Audio Research SP 6C Cassiel Analogue Source 8 4th November 2012 10:03 AM
Tango MCT-999 MC Cartridge Step-Up Transformer Wiring Help HP8903B Analogue Source 8 29th March 2012 04:19 PM
Copyright 1999-2017 diyAudio
