MC step-up transformer
Old 9th May 2013, 10:43 AM   #11
guglielmope is offline guglielmope  Italy
Very interesting!
And how about the type of wire?
Ciao
Guglielmo
Old 9th May 2013, 10:46 AM   #12
EUVL is offline EUVL  Europe
Not worried about high inter-winding capacitances in a toroid ?
Also the second link for th 6025F did not return an item for purchase, despite registration ....
Patrick
xen-audio.com
Old 9th May 2013, 11:51 AM   #13
esltransformer is offline esltransformer  Georgia
Banned
sure I worried but after all the bandwidth is about 300KHz.
Sekels have a smaller core I just saw:
Online Catalog & Consulting - T60006-E4025-F001 T60006-E4025-F001
Patrick
Old 9th May 2013, 12:15 PM   #14
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Could you elaborate about tourns ratio for several gains and wire type? I need 1:10 20dB for a Denon DL103R?
Old 9th May 2013, 12:15 PM   #15
Many thanks for the quick response.
Clicking on the links still returns "No Product found".
Maybe just my problem.
In any case, what would be the loading on the cartridge ?
Or what would be a suitable cartridge ?
Patrick
xen-audio.com
Old 9th May 2013, 12:17 PM   #16
> Could you elaborate about turns ratio for several gains and wire type? I need 1:10 20dB?
40-turn primary / 600-turn secondary is 1:15.
But this is only more parameter out of many ....
Patrick
xen-audio.com
Old 9th May 2013, 12:50 PM   #17
Banned
I can open the links i sended, i don't know if more people here cannot open them.
You find the Al-value in the links also so it's easy to calculate the minimum windings required.
btw what else you want to know?
Patrick
Old 9th May 2013, 01:10 PM   #18
The Denon DL-103R has an impedance of 14 ohm.
Would your above example in post #11 be suitable ?
What would be the typical leakage inductance ?
Should a shield be put on the outside ?
I am total idiot with transformers, so apologies for stupid questions.
Patrick
xen-audio.com
Old 9th May 2013, 01:15 PM   #19
On Hiatus
SY's Avatar
The 103 is spec'd at 40R, and the samples I've seen were closer to 50R.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 9th May 2013, 01:18 PM   #20
You are absolutely correct with the DL-103 :
Denon DL-103 Phono Cartridge
The DL-103R, however, has different specs :
Denon DL-103R Phono Cartridge
Patrick
xen-audio.com
MC step-up transformerHide this!Advertise here!
Ferrite core transformer design step by step Aucosticraft Power Supplies 159 20th June 2015 03:20 PM
Choose proper load resistance for MC step-up transformer rongon Analogue Source 21 15th February 2014 11:26 AM
nuvistor MC step up reinhard Tubes / Valves 66 14th February 2014 02:27 PM
Step-up MC transformer for Audio Research SP 6C Cassiel Analogue Source 8 4th November 2012 11:03 AM
Tango MCT-999 MC Cartridge Step-Up Transformer Wiring Help HP8903B Analogue Source 8 29th March 2012 05:19 PM
