My Teres bearing project
Old 7th April 2013, 04:58 PM   #11
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Theoreticaly you are right about balance, this is not a casting but solid material.
I would still check it though.
You can do a quick and dirty balance by placing 3 springs under a test plinth with your bearing bolted to it.
Start moving the 3 springs (Y arangement) equally closer and closer increasing sensitivity, toward the center bearing and simply watching the outer rim spining the platter by hand.
I did this on a 1" acrylic with lead rimed grove and had to adjust accordingly.
The sonic difference was incredible before and after!
This simple technique will eliminate any assumptions
Looking forward to your completed design!
David
Old 7th April 2013, 05:08 PM   #12
fmena is offline fmena  Canada
Thumbs up THANK YOU STEVE!!!
I have the Maxon A-Max motor with Mark Kelly's motor controller and your tip has really helped!
Cheers
Frank M
Cheers
FM
Old 7th April 2013, 06:02 PM   #13
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 My Teres bearing project
David
Except the assumptions that you springs have identical perfection linear deflection for any given load....
Paradise Pre-reg PSU PCBs
Old 7th April 2013, 06:22 PM   #14
Conrad Hoffman is offline Conrad Hoffman  United States
IMO the spring technique should work well. It will either vibrate or it won't. Even if the k of the springs is different you'll know when good balance is achieved. I was thinking it could also be done static, doing up some fixture like a bubble tire balance machine. You just have to get the cg in the right place to have sensitivity.
I may be barking up the wrong tree, but at least I'm barking!
Old 14th April 2013, 11:12 AM   #15
quan is offline quan  Australia
Originally Posted by user510 View Post
Mine had the A-Max 110189. I had several upgrades of the controller. Which was of the original Manfred design. This controller, while providing a rather neat on/off feature was probably the weakness and cause for the laid-back sound qualities of the deck. I presume the Mark Kelley controller should impart a very different character. The motor itself has power. I think I once figured that at 33-1/3rd platter rpm, my motor was outputting 8watts.
Please note that the reason I call my old Teres "laid back" is because when I got a TD124, I discovered what the opposite of laid back is.
Another thing I learned about the A-Max. It requires periodic oiling. If not, the motor starves for lube. Not good. Figure once a year, re-oil its bushings.
-Steve
Hi Steve, you mention re -oiling for maxon motor. My turntable maxon motor has been running for a few years now without re-lubbing. Do you mean re-grease of the bushings?.
Quan
Old 14th April 2013, 03:51 PM   #16
user510 is offline user510
user510's Avatar
Quan
Yes bushings. See item 13 in the illustration: But not grease. Oil. Electric motor oil. approximately 20 wt.
-Steve
Old 14th April 2013, 10:09 PM   #17
Thank you Steve, pardon me i can't see any recess for oiling. Do you just use a small pipet to drop the oil in? And how much roughly. I tried to open my motor last night but really stuff up those small screws badly.Huh.
Quan
Old 14th April 2013, 10:14 PM   #18
user510's Avatar
Quan
There is only access to one of the bushings. The one at the pulley end. This is oiled by dripping onto the shaft and allowing gravity to pull the lube in. I've no idea how to get oil the the other end without a complete motor disassembly.
I do know that the upper bushing can go dry. It has on me, anyway. And when I lubed the one bushing, the motor began operating normally again.
-Steve
Old 14th April 2013, 10:30 PM   #19
Thank you Steve the picture posted got me confused as it showed the other end of the motor.
Old 14th April 2013, 11:19 PM   #20
user510's Avatar
Yes. This photo shows the commutator and brushes. The grease is for the precious metal brushes. Platinum, I believe.
In order to gain access to the bushing and shaft just below, the motor must be further dismembered. I never bothered. Instead, I got into TD124's. Those are more maintenance friendly.
-Steve
My Teres bearing projectHide this!Advertise here!
Teres Bearing 615498 Swap Meet 0 5th January 2013 07:10 AM
Teres Bearing - How heavy can it take? DaveM Analogue Source 3 9th November 2010 06:53 PM
What are you doing with your new Teres Bearing wirewiggler Analogue Source 42 30th June 2009 06:44 PM
Teres platter and bearing randytsuch Swap Meet 3 26th September 2007 04:35 AM
WTB: Teres bearing (or equivalent) ckniker Swap Meet 0 20th September 2007 06:25 PM
