ALPS RK27 100K log dual
Old 4th April 2013, 11:20 AM   #1
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Default ALPS RK27 100K log dual
I know how install the potentiometer but I see at audio-gd another way and supposed improved to connect the pot, is OK? the resistor value have to be 20% of pot value or other value?
TIA
Felipe
Old 5th April 2013, 11:06 AM   #2
lcsaszar is offline lcsaszar  Hungary
Each solution has its place. The first provides relatively constant high load resistance to the previous stage, but variable source resistance (that could go up to as high as 25k) for the next stage. The second has variable load for the previous stage (that could go as low as 20k), and relatively constant low source resistance for the next stage, but you will have some attenuation at max volume. The second version has less noise due to lower resistance at the input of the next stage.
So it depends on the driving and load requirements which is the better topology. Ideally the value of the potentiometer should be > 10x the source resistance, and < 10x the load resistance. That means the souce resistance should be < 10k, and the input resistance of the next stage should be > 1M, as typical for tube amplifiers.
Don't get fooled by any explanation about shorter/straight signal path
Old 5th April 2013, 11:31 AM   #3
Thanks, if I want to use 2nd pic wich resistor value is necessary?
Old 5th April 2013, 11:48 AM   #4
It is not possible to answer your question without knowing:
- the output impedance of the stage driving the volume pot
- the minimum allowed load impedance of this stage
- the input impedance of the next stage
- the maximum allowed source impedance for the next stage
- signal level (for noise aspect)
In general, the lower serial resistance is the better, if the previous stage tolerates it Are you sure this is the optimal topology for your application?
Old 5th April 2013, 12:05 PM   #5
One case for ECC81 mu-follower, other case for #26 preamp, mu follower driving headphones 300 ohms, #26 preamp driving SS 100k input impedance
Old 7th April 2013, 10:43 AM   #6
Wich resistor value is necessary for 2nd pic?
Old 7th April 2013, 11:50 AM   #7
4.7k seems to be a good value to start with.
Old 7th April 2013, 02:57 PM   #8
OK I will do & let you know how it works.
Old 7th April 2013, 04:03 PM   #9
4K7 sounds too loud or it's 47K the correct value?
Old 8th April 2013, 10:00 AM   #10
Too load at max volume? Then perhaps you can lower the gain of the first stage. Easiest way is to remove the cathode resistor... Or use a simple cathode follower. Have you seen somewhere these three parts (preamplifier, volume control, power amplifier) recommended together?
ALPS RK27 100K log dualHide this!Advertise here!
FS: ALPS RK27 series RK27112 dual 20K (for B1) and RK27114 quad 50K (for balanced) zhoufang Vendor's Bazaar 35 13th April 2013 02:09 PM
Alps dual log 10k volume control Praudio Swap Meet 5 20th December 2008 10:22 AM
ALPS RK27 DUAL 50K LOG Pots - Unused thermionic Swap Meet 14 29th March 2008 01:22 AM
Alps rk27 jkostans Chip Amps 2 13th January 2007 11:33 PM
Looking for a Substitute: Alps RK27 Bassterror Solid State 0 14th August 2006 10:51 AM
