4 into 1 Phono
4 into 1 Phono
Old 25th March 2013, 10:09 PM   #1
MLStrand56 is offline MLStrand56
Default 4 into 1 Phono
Now I'm convinced that I need to build a 4 into 1, Line Level, Phono Switcher.
I need 4x Phono RIAA pre-amp ckt. boards. I also need to be able to switch IN/OUT a MC Head Amp to Any of the 4 Phono ckts.
I know this is expensive, but I need Quality!!!! I'm a Vinylphile!!!
MLStrand56
Old 25th March 2013, 11:53 PM   #2
counter culture is offline counter culture  United States
A vinylphile is one thing, but what have you got? 8 ears?
Old 26th March 2013, 02:20 AM   #3
andyr is offline andyr  Australia
At line level, this shouldn't be a problem: Lorlin make a 5-in/1-out stereo switch, which is used for source selection in my preamp.
I need 4x Phono RIAA pre-amp ckt. boards. I also need to be able to switch IN/OUT a MC Head Amp to any of the 4 Phono ckts.
If you need to be able to switch IN/OUT an MC head amp to any one of the 4 phono circuits ... this must be done at MC signal level (not line level). IME, you will degrade the signal by inserting any kind of switch at these low signal levels.
So if you're an "audiophile" ... you won't do this.
Andy
Old 26th March 2013, 02:31 AM   #4
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I would switch the outputs of the pre amps.
PCBCAD51 pcb design software. 2018 version out now. https://www.ebay.co.uk/itm/253272755...84.m1555.l2649
Old 26th March 2013, 11:47 AM   #5
lcsaszar is offline lcsaszar  Hungary
The OP did not say the 4 RIAA boards will be identical. Perhaps his intention is to compare them, or using the right sounding one for each LP
Old 26th March 2013, 05:31 PM   #6
Default 4 Turntables.
No I have two Yamaha PX-3's, one Bang & Olfsen 4004, & one Technics SL-1400 Mk2. I have various cartridges for different kinds of music or LP condition.
Not 8 ears, but 10 ch's. Five x Yamaha MX-1000U Amps.
MLStrand56
Old 26th March 2013, 05:42 PM   #7
Default MC switch
Originally Posted by andyr View Post
If you need to be able to switch IN/OUT an MC head amp to any one of the 4 phono circuits ... this must be done at MC signal level (not line level). IME, you will degrade the signal by inserting any kind of switch at these low signal levels. So if you're an "audiophile" ... you won't do this.
Andy
Of course the MC amp (or step up XMFR) must be inserted before the phono EQ ckt!!! I know the MC amp can be switched in/out (probably electronically). If not, how do you explain the MC/MM switch on many pre-amps with only one phono ckt?
I never said or implied that this would be easy. I know for certain that it's Not impossible! I just don't give up as easily as you apparently do.
MLStrand56
Old 26th March 2013, 05:57 PM   #8
Default Output Selector
The outputs of my Pre-Amp (Sony TA-E2000ESD) go to a pair (L & R) of Yamaha DSP-1's. Or are you talking about a line level output selector After the Phono EQ ckt? That's where I would put the selector switch. I think a 4-pos rotary switch would work great.
MLStrand56
Old 26th March 2013, 06:05 PM   #9
Default Identical RIAA boards
I think that 4 x identical RIAA boards is the best way to go.
Compare what? I do use each turntable differently. Also the condition of the LP dictates which TT & Cartridge I use.
MLStrand56
Old 26th March 2013, 08:38 PM   #10
Yes, some components have an MC/MM switch - a mate of mine has one. However, because he only listens to HOMI Grado (his RR1), he removed the switch - and he said the sounded better, as a result.
IOW, the switch - when it was in place - was degrading the cartridge signal.
It's not impossible to switch the cartridge input signal - but if you do this, the sound will be degraded, compared to if there was no switch. Therefore I do not do it, because I like to have the best sound I can get. You are free to make a different choice.
Andy
4 into 1 PhonoHide this!Advertise here!
Phono Preamp PCB wanted - Transcendental Sound Grounded Grid Phono Preamp nathanjh13 Analogue Source 0 14th June 2012 11:19 AM
Need to change phono gain on Rowland phono module Mikelo Solid State 0 4th October 2009 02:43 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 06:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 10:51 PM
Phono transformer VS Active phono pre ckwong99 Analogue Source 0 2nd November 2005 05:35 AM
Copyright ©1999-2017 diyAudio
