Mr. Marsh's neat MC preamplifier - Page 2 - diyAudio
Old 16th March 2013, 12:58 AM   #11
scott wurcer's Avatar
The MPSA18 is a very poor choice as an example, you shouls at least pick a transitor intended for ultra-low noise operation like the MAT-02 or the THAT Corp equivalents.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 16th March 2013, 08:06 PM   #12
This 2N5087 spec sheet gives a better example of what I am suggesting. See figure 12 of En vs Ic.
http://www.fairchildsemi.com/ds/MM/MMBT5087.pdf
I think the calculated MPSA18 Rbb is about right. I have some measured data I will try to find. I recall that the MPSA18 Rbb was not very low for a supposed low noise transistor.
Old 16th March 2013, 08:39 PM   #13
jackinnj's Avatar
FWIW, there's an error in equation 5.11 of "The Sound of Silence" -- Boltzmann's constant should be squared in the first term.
Old 17th March 2013, 02:56 AM   #14
Joachim Gerhard's Avatar
Here is a circuit that biases in input common base stage in a different way :
Patent US6069534 - Balance photo-receiver with complementary HBT common-base push pull pre ... - Google Patente
Here you can run the input transistors on more current then the base current of the second stage.
Old 17th March 2013, 04:39 AM   #15
Here is another way to set the input idle independently.
Old 17th March 2013, 01:10 PM   #16
jackinnj's Avatar
Originally Posted by Joachim Gerhard View Post
I would run at least 5mA, better 10mA in the input stage and use low Rbb transistors.
This is just part of the equation -- summing square of kernel, current and thermal noise. So is there such a big difference between 5mA and 10mA?
Old 17th March 2013, 01:37 PM   #17
I have a cartridge with 4 Ohm impedance so yes, i say 10mA makes a difference.
It may not be big but even in your graph you can see the difference at lower impedances.
Is that 1 or 2dB ?
Also when you make an open loop phono stage the higher Gm on higher idle can be an advantage.
Old 17th March 2013, 06:23 PM   #18
I found the data on the MPSA18. It took awhile because I was looking for MPSA18 but the data is for both the 2N4101 and MPSA18 transistors. Apparently they are similar transistors. The measured Rbb is given as 900 Ohms.
Old 17th March 2013, 06:26 PM   #19
and very close to
same estimate of Rbb, 810 ohms
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th March 2013, 08:15 PM   #20
jackinnj's Avatar
Is that 1 or 2dB ?
If you optimize Noise with respect to I(collector) -- this visual should demonstrate how much there is (or is not) gained:
John Curl Mc Kinnie phono pre-preamplifier Antoni Rende Solid State 14 14th January 2017 10:27 AM
"...the best preamplifier ever made" says Mr. David Price, Hi-Fi- World tiefbassuebertr Analog Line Level 72 10th April 2013 08:50 PM
Musical Surroundings MM/MC Phonomena Phono Preamplifier kp93300 Analogue Source 0 11th October 2009 02:15 PM
HQ Balanced Phono Preamplifier for MC Cartridges using OPA2604 BiepBiep Analog Line Level 5 1st November 2008 06:27 AM
Copyright 1999-2017 diyAudio
