Mr. Marsh's neat MC preamplifier
Old 12th March 2013, 01:21 PM   #1
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default Mr. Marsh's neat MC preamplifier
RNM published this design in The Audio Amateur 1/1982 -- there were a couple corrections in 2/1982. It features very low input impedance and use of easily attainable components, no "impossible to source high gm P-jfets". I've changed the schematic to reflect the corrections, and updated to include the OnSemi devices which are readily available as well, and more easily attached to a heat sink:
It was suggested in the "Bipolar Transistor Tester" thread that 2N4400/03 would be lower noise. Of course component values would have to change. Could also use the THATCorp low noise P and N matched transistors.
Old 12th March 2013, 01:45 PM   #2
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Doesn't this circuit need to include the resistance of the cart, besides the cart is DC connected?
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 13th March 2013, 12:06 AM   #3
rayfutrell is offline rayfutrell  United States
The 2N5210 and 2N5087 aren't ideal because they have a base spreading resistance of around 150 Ohms, if I recall correctly. Quad used the Zetex ztx650 and 750 in their MC preamplifier in the QUAD 44 and 34 because of the very low base spreading resistance of these transistors. Toshiba made transistors with incredible low base spreading resistance that would be ideal for this application but they seem to be unobtainable now.
Old 13th March 2013, 03:55 AM   #4
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
As far as i can tell, the current in the input stage is the base current of the output transistors. That can not be much so this circuit is far from optimum noise wise with low impedance cartridges connected.
I would run at least 5mA, better 10mA in the input stage and use low Rbb transistors.
Old 15th March 2013, 07:34 PM   #5
jackinnj's Avatar
Got me to think of how to measure Rbb directly -- Burkhard Vogel has a method in Chapter 5 of "The Sound of Silence" --
Old 15th March 2013, 08:17 PM   #6
You can make a good estimate of the Rbb by looking at the graph of voltage noise (nv rt Hz) vs collector current. Typically the noise decreases with collector current and bottoms out at some low value. Calculate the resistor value that gives that noise. Just remember, 1K resistor = 4 nv rt hz, 250 Ohm = 2 nv rt hz and 62 Ohms = 1 nv rt hz.
Old 15th March 2013, 08:33 PM   #7
Just fit the input noise vs Ic to a plot of the root-sum squared re and rbb. The rbb that makes the best fit is a good guess. There are high current effects that can mess things up a little at large Ic so you might not get a perfect relationship but good enough.
There is a web site that uses RF power transistors that are even better (at least the npn) than the Toshiba devices were.
Old 15th March 2013, 09:10 PM   #8
Mark Johnson is offline Mark Johnson  United States
Here's the MPSA18 datasheet http://www.onsemi.com/pub_link/Collateral/MPSA18-D.PDF
I guess you're talking about Figure 2. Looks like noise bottoms out at 3.6 nv rt hz which is equivalent to an 810 ohm resistor; is that your estimate of Rbb?
Old 15th March 2013, 10:07 PM   #9
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
The figure you posted shows the noise voltage increasing with current rather than decreasing.
RJM Audio (phonoclone.com / G+)
Old 15th March 2013, 10:28 PM   #10
Oops, yes you're right! I posted Figure 2 of the MPSA18 datashseet, but Figure 3 might be closer to what member rayfutrell had in mind. Interestingly the "bottom out" point is about the same, approx 3.6 nv rt hz, leading to the same estimate of Rbb, 810 ohms. But 810 ohms seems awfully high.
Mr. Marsh's neat MC preamplifierHide this!Advertise here!
"...the best preamplifier ever made" says Mr. David Price, Hi-Fi- World tiefbassuebertr Analog Line Level 73 21st May 2017 04:51 PM
John Curl Mc Kinnie phono pre-preamplifier Antoni Rende Solid State 14 14th January 2017 09:27 AM
Musical Surroundings MM/MC Phonomena Phono Preamplifier kp93300 Analogue Source 0 11th October 2009 01:15 PM
HQ Balanced Phono Preamplifier for MC Cartridges using OPA2604 BiepBiep Analog Line Level 5 1st November 2008 05:27 AM
Copyright ©1999-2017 diyAudio
