Mr. Marsh's neat MC preamplifier Mr. Marsh's neat MC preamplifier - Page 4 - diyAudio
Old 18th March 2013, 07:58 PM   #31
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
The DL103 is a poor choice by modern standards.
It has 40 Ohm Johnson noise and not much output.
Old 19th March 2013, 01:47 PM   #32
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
The DL103R is 14 Ohms. What's the point anyway? It's easy to get the background noise well below the noise when dropped into an unmodulated grove.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 19th March 2013, 05:51 PM   #33
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I would like to suggest that replacing R4 (825k) with a red LED will drop the noise pretty significantly.
Just happen to have a bunch of THAT340's on hand...
Old 14th September 2013, 12:42 AM   #34
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Hello --
I didnt even know this subject existed until doing search on the Web about measuring Rbb and saw this .....
i owned a Denon DL103 so that is what i used. Medium output voltage.
I just had access () to those transistors I used - so i used them. No attempt to make the worlds lowest noise MC step-up but it was very quiet in the home music system. I had a Denon step-up transformer to compare against for noise and distortion and response.
The important point I wanted to find out was -- if a lower than 100 Ohm cart load (the typical MC value used) made the sound have lower distortion as was reported via listening by Peter Moncrief, then could I make the input Z of a MC pre-preamp with a very low z and would it sound even better -- or at least better than what I had been using. What would it sound like to My ears. The passive Rload on the cart had been to make it sound 'cleaner' and lower distortion but, of course the cart output level was reduced as well. So it was just an interesting affect but not practicle.
It was developed to provide a very low input Z, direct coupled as much as possible and a sysmetrical design with the benefit of lower distortion coming off the cartrdige.
--- now that i dont even have a phono/LP any more --- to maximize its potential with better transistors etal. I gave it to Kavi, also. If I had a phono system I would love to hear what improvements you will make to it.
Eventually - try to see how the cartdrige distortion is affected, somehow.
The gain is somewhat self leveling by input Z of cartdrige, it seemed [lower output and lower Z cart... higher gain]. well, that was the idea. i dont remember much more about it anymore. I hope this info helps you in some way.
Enjoy !
Thx-RNMarsh
Old 15th September 2013, 05:58 PM   #35
RNMarsh's Avatar
Linear Audio will be publishing a remake of this MC pre-preamp topology but using fet's instead of bipolars. Should be interesting.
Thx-Richard Marsh
Old 20th September 2013, 08:45 AM   #36
RNMarsh's Avatar
Has anyone put this little circuit to the SIM yet?
might be good - might be bad. Erno's method should be fine I would imagine. I had the JC MC (battery powerd) pre-preamp and a Denon transformer that is made for the Denon 103 cart and could compare but could not measure things like s/n and distortion at MC levels back then. At that time, I had a high efficiency custom made 3-way all JBL system and there was no noise heard (all horn... bass... mid..highs). Triamped with custom variable crossover and seperate amps. It was quiet and sounded the best of the three. I cant remeber any tech details this far beyond it.
Still looking for a follow-up on how much the distortion from the cartridge is reduced at the input to the amp via low Z loading.
THx-RNMarsh
Mr. Marsh's neat MC preamplifierHide this!Advertise here!
"...the best preamplifier ever made" says Mr. David Price, Hi-Fi- World tiefbassuebertr Analog Line Level 73 21st May 2017 04:51 PM
John Curl Mc Kinnie phono pre-preamplifier Antoni Rende Solid State 14 14th January 2017 09:27 AM
Musical Surroundings MM/MC Phonomena Phono Preamplifier kp93300 Analogue Source 0 11th October 2009 01:15 PM
HQ Balanced Phono Preamplifier for MC Cartridges using OPA2604 BiepBiep Analog Line Level 5 1st November 2008 05:27 AM
Copyright ©1999-2017 diyAudio
