| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
First, a few pics:
1. |
#2 |
2.
#3 |
3.
#4 |
4.
#5 |
Very nice looking! It looks as though it was a ton of work. How is the sound?
#6 |
What a nightmare! Can't possibly sound half as good as a simple ELMA/Seiden switch. But it glows and may even have remote...
#7 | |
The metal work and layout is done very nicely though. And I kind of understand the design choices here. Using knobs would change the visual character of the unit and remote is probably easier to implement this way than with knobs. I've seen similar unit on the Bent Audio board selling for $10K, although it's using knobs ![]() http://www.audiocircle.com/circles/v...8076714a35d4cc
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#8 | |||
Regards |
#9 | |
With regards to my S&Bs, initially I was under the impression that TXs dull the highs or take a bit of sparkle at the top end, but after constant using for several weeks, I either got used to it or they simply burned in. They sound very satisfactory now and frankly I don't see a need for an active preamp. They also work well with GC, which are my main amps now.
#10 | |
Hi, I'm using a somewhat unusual combination of 2 transformers per channel (Sowter 9150 + 9155; 4X10dB + 5X2dB). So far so good. Regards |
| rational approach | traw | Multi-Way | 2 | 15th August 2006 07:39 AM |
| here's my approach | hitsware | Solid State | 2 | 13th November 2004 04:54 AM |
| I2S approach....newer DAC's | Lyra | Digital Source | 1 | 1st February 2004 04:29 PM |
| A less used approach | SuppersReady | Pass Labs | 18 | 29th January 2003 11:16 PM |
