New DIY TT... almost finished...pics
Old 21st November 2003, 03:45 AM   #1
Illusus is offline Illusus  Canada
Illusus's Avatar
Default New DIY TT... almost finished...pics
I'm almost done my new TT, had it set up for first time to take measurements and thought I may as well take some pics. I won't go into full detail yet, too busy working on it.
The plinth is made of layers of mdf, delrin and baltic birch ply. It is filled with two bags of no.2 lead shot, sand and linseed oil. I used micrometer heads for levelling.
The platter is a rek-o-kut k-33h. I polished the spindle and bearing housing. The four holes in the platter are threaded to accept brass weights, still waiting on those and a ceramic ball and teflon thrust plate. The pic shows it dirty from handling.
The motor is an inverted pabst, again from a rek-o-kut. I really like this motor, very quiet, it's overbuilt, inverted design (the can spins, not the armature) creates a nice flywheel effect. A micrometer head allows for tilt adjustment. The case is made of 4" PVC pipe and (tempararily) HDF, alluminium top and bottom plate are in the works.
The arm board in the pic has yet to be painted, layered delrin and mdf. A Roksan tabriz arm is mounted for now, my ongoing Ladegaard project is in it's fourth stage of revision. I am designing an arm board that will allow the use of both arms.
The likeness to a Teres is totally unintentional, form followed function and it ended looking like that. The finish is by no means perfect, looking close one can tell the layers are there in places, a minor disappointment, I had limited time to work on this and will refinish it in spring when the weather is more accomodating.
Hope you guys like it. I can't wait to hear what it can do.
Bart G.
Old 21st November 2003, 04:18 AM   #2
psarin is offline psarin
Default Great Work!
Almost exactly what I have been playing with - a Rek-O-Kut K-12 platter (mine is filled
with lead+oil). Unfortunately, that's all I've got so far. The plinth I am working on is triangular - I plan to mount 3 motors, one at each corner, and have the air-bearing arm stand off
on the back side.
Talking about motors, if you want to go the DC motor route, there's a guy on eBay who sells
surplus maxon motors. He has the motors used in the Teres for $9 each! You just tell
him the part number of the maxon motor (easy to look up from the online catalog) and he probably has'em. I've been working out a DC voltage controller
to drive three motors taking a lot of hints from the Teres project.
Let us know how it sounds!
Cheers -
P
ps: the guy on eBay who sells surplus Maxon motors is SEQUOIAGP@aol.com
No affiliation of mine (apart from having bought good motors from him).
Old 21st November 2003, 12:03 PM   #3
Merijn is offline Merijn  Netherlands
Looks awsome!
I wonder where I could find a rek-o-kut k-33h...(Let's Google...)
With this platter came the bearing too? Or have you made the bearing yourself?
Old 21st November 2003, 04:50 PM   #4
Tazzy is offline Tazzy
Send a message via MSN to Tazzy
Could have been a dutch inside joke that rek-o-kut.
Don't want to be banned again so I won't explain what it means ;-)
Old 23rd November 2003, 01:46 AM   #5
Illusus's Avatar
Merjin:
the platter came with the bearing. It's a nice robust, well polished bearing with a spiral channel cut in the shaft to bring oil to the top. They seem to appear on ebay quite often as complete turntables marked K-33 or N-33. Previously I used a bearing and platter from a Thorens TD-160, good quality but too small to add a heavy weight platter to without stress or worry. Good luck in your search.
Old 23rd November 2003, 01:50 AM   #6
Illusus's Avatar
Sorry for misspelling your name Merijn
Old 24th November 2003, 09:09 AM   #7
No problem Illusus, even in my own language people ar spelling my name often wrong...
In my case, the reason for looking for another platter with bearing is also a TD160, but in my case the spindle has a really bad scratch on the bearingball. It is not mooving freely anymore and produces a lot of noise.
Rebuilding would be an option, but a homebrew TT is much more appealing
Since I have not been searching this forum, I'll start with that, but youve inspired me to proceed!
Old 25th November 2003, 03:17 AM   #8
Illusus's Avatar
Thank you.
Although I was planning on using it for a simple TT to give to a friend for Christmas,I may be persuaded into giving up my TD160 bearing, platter and motor. I like your enthusiasm.
Old 25th November 2003, 12:41 PM   #9
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Have you tried looking for a replacement part?
Back when I had a 160 I added PTFE particles suspended in oil to the bearing assembly. (Slick 2000 as used for car engines)
It ran much better after that.
Frank
Old 26th November 2003, 12:33 PM   #10
Have been thinking of Slick 2000. But my Fiat Panda doesn't need it anymore after 20 years
Now I'll just have to try, I mean that's tweaking all about, right?
Illusus:
I really appreciate your willingness (hope this is ok english)! But I think the costs of shipping it to Europe would be pretty expensive, I guess. There have to be a good Thorens on this side of the globe, they are German made... I'll start E-baying right away.
Have to go to college now,
New DIY TT... almost finished...picsHide this!Advertise here!
Finished - Pics of my new TL Speaker :) Xmax BR Subwoofers 4 10th October 2006 12:10 PM
Finished Pics Of My First Sub c3ham Subwoofers 9 11th September 2006 10:44 AM
Your pics of a finished AV800 nikonfanatic Solid State 12 13th July 2004 02:37 AM
Speakers finished pics Stew320 Multi-Way 12 24th August 2003 04:17 AM
pics of my leach amp - just finished BrianGT Solid State 35 11th February 2002 06:50 AM
Copyright ©1999-2017 diyAudio
