2nd phono stage advice: looking at the kits
Old 13th September 2013, 09:58 AM   #41
smallangryboy is offline smallangryboy  United Kingdom
Sachin do you have a photo of the top side of the PSB ? Modelling in Sketchup so I can move it around for clearance checking.
Old 13th September 2013, 10:02 AM   #42
sachu888 is offline sachu888  India
sachu888's Avatar
I have few original Pics of bare and populated boards.Here are they
Power supply: Click the image to open in full size.
Sachin
Old 13th September 2013, 10:19 AM   #43
Perfect, many many thanks
Old 14th September 2013, 06:48 AM   #44
Hi Sachin, this is looking like a good solution for me. Just wondered, could tell me if I could drive the power supply effectively from the transformer on the Hypex AS2.100?
I'm using this as a donor for my amp project.
Cheers
Old 14th September 2013, 06:52 AM   #45
sachu888's Avatar
Cheers
I don't know about transformer used in Hypex AS2.100.This power supply will need 15-0-15 transformer.I am using 22-0-22 30 VA R core transformer to run Passb1+LDR volume control+CNC and SSP.I will send you Power supply building manual if you PM your mail id.
Sachin
Old 23rd September 2013, 04:05 AM   #46
batty is offline batty  Australia
I use a Hagerman Bugle 2, changed R3 and R8 in both channels to 560 ohms to give 54dB of gain and replaced the optional 100 ohm resistors for 200 ohms as that suits my cart best.
Townshend Rock II, My new TT since 1986.
Old 5th August 2014, 08:43 PM   #47
noviygera is offline noviygera  United States
I have tried the Boozehound now with both batteries and recommended PS. It is a little "polite" and lacking in dynamics for my taste, sounding a bit slow. Although it is very detailed and spacious, open sound.
Can anyone recommend a very good sounding op-amp phono, so that I can try something different? Something dynamic, fast, and at the same time natural, detailed.
Thanks,
Herman
Old 5th August 2014, 09:01 PM   #48
andyr is offline andyr  Australia
Thanks,
Herman
What about Rod Ellioot's P06?
See here: ESP Projects Pages - DIY Audio and Electronics
With P05 power supply.
Andy
Old 5th August 2014, 09:53 PM   #49
Stereo mm Phono RIAA Preamplifier Module Board OPA2134 | eBay
Lite CT4 mm Phono Stage Amplifier Circuit Board Finished Board | eBay
anyone familiar with the above two?
Old 5th August 2014, 11:53 PM   #50
fap is offline fap  Australia
G'day all, based on personal experience with building many ESP P06 phono stages, I have never heard a phono stage with such superb dynamics. Regards, Felix.
2nd phono stage advice: looking at the kitsHide this!Advertise here!
A.N.T. Audio Kora 3T phono stage DIY kits available x-pro Vendor's Bazaar 0 19th December 2012 09:32 AM
Phono stage advice davecooper Analogue Source 9 13th November 2010 04:10 PM
Advice on hum in phono stage smbrown Tubes / Valves 2 4th November 2009 06:46 AM
RIAA opamp phono stage advice mp741 Analogue Source 19 7th February 2006 08:49 PM
