2nd phono stage advice: looking at the kits
Old 10th September 2013, 06:25 PM   #31
noviygera is offline noviygera  United States
Sachin,
pm sent to you.
Old 11th September 2013, 02:58 AM   #32
sachu888 is offline sachu888  India
sachu888's Avatar
Originally Posted by noviygera View Post
Sachin,
pm sent to you.
Pm replied.
Sachin
Old 13th September 2013, 09:14 AM   #33
smallangryboy is offline smallangryboy  United Kingdom
deleted
Old 13th September 2013, 09:20 AM   #34
sachu888's Avatar
Originally Posted by smallangryboy View Post
Sachin, can you run this from a power supply rather than batteries and if so any recommended configuration?
Yes why not.We have designed one power supply based on LM317/337 with adjustable output.You can adjust the output by 5k trimmers and DMM.I am running my CNC Phonostage,Pass B1 and SSP with only one Power supply.You can see Power supply pics here Introducing the (mini) Tower of Power - AudioKarma.org Home Audio Stereo Discussion Forums and here Another Super High End Phono Stage! No expense spared... - Page 72 - AudioKarma.org Home Audio Stereo Discussion Forums
Sachin
Old 13th September 2013, 09:21 AM   #35
Cool cheers
Old 13th September 2013, 09:24 AM   #36
How big is the board? Sorry if I've asked that before!
Old 13th September 2013, 09:27 AM   #37
sachu888's Avatar
CNC Phonostage is 101.60 X 76.20 MM and Power supply 100 X 76.19 MM
Here is the new CNC Phonostage layout is optmised for bigger caps of various sizes.
Sachin
Old 13th September 2013, 09:31 AM   #38
Perfect thanks.
Old 13th September 2013, 09:34 AM   #39
Last Q for now as I'm just organising the board positions in my enclosure, do you know the rough height when the boars are populated?
Old 13th September 2013, 09:40 AM   #40
sachu888's Avatar
There are 5 tall caps of 4700uf in Power supply so max height of populated board would be 37mm plus whatever PCb standoffs you use.
Sachin
2nd phono stage advice: looking at the kitsHide this!Advertise here!
A.N.T. Audio Kora 3T phono stage DIY kits available x-pro Vendor's Bazaar 0 19th December 2012 09:32 AM
Phono stage advice davecooper Analogue Source 9 13th November 2010 04:10 PM
Advice on hum in phono stage smbrown Tubes / Valves 2 4th November 2009 06:46 AM
RIAA opamp phono stage advice mp741 Analogue Source 19 7th February 2006 08:49 PM
