Turntable bearing question.
Old 5th February 2013, 01:45 PM   #21
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Turntable bearing question.
Originally Posted by BenY View Post
Belt location on the platter cannot influance motor load in any way,unless the diameter of the platter changes from top to bottom. but then speed will change too.
The only issue i see here is centering the force applied by the belt with the center of the bearing so the bearing will be loaded evenly, so wear will be minimal.
What Ben said, unless you have huge belt tension you are unlikely to upset the apple cart. A decent inverted bearing, yours is that design, should be self stable as the mass in beneath the point of contact.
Nothing to worry about.
Paradise Pre-reg PSU PCBs
Old 5th February 2013, 01:52 PM   #22
If it's the TB21 that you've bought it should be fine. It'll be interesting to see the motor and controller to give advice on improving that. If it is a DC motor it should at very least use a simple current sensing feedback loop to control the speed stability. Do you have any pics of the PSU and motor?
Old 5th February 2013, 06:54 PM   #23
Arckivio is offline Arckivio  United Kingdom
I've added some motor pics & as far as I can see there's just the potentiometer & a couple of resistors. I always knew this knew this would take a bit of tinkering to get it as good as it can be so any help is great. Help with the motor would be great too, although I am surprised at how quiet the motor is & the very low background noise & rumble from the turntable in general. The motor only has 5.5v wall wart type psu. Any advice on improvements I could make are very much appreciated. Thanks to everyone that has responded so far.
Old 6th February 2013, 01:28 PM   #24
Ok, looks like it's just a straight DC motor controller with no regulation on there at all. There's plenty that you can do for it, but not much that will fit in the motor housing. It would benefit from a simple current sensing DC motor controller. I imagine there are examples on the forum somewhere.
Old 6th February 2013, 09:34 PM   #25
I had been looking at controllers already but they're way beyond my electrical capabilities. I can't even read a schematic!!! I'm OK with mechanical tinkering but the only thing I could build for the controller is its case as I work in sheet metal. A step by step picture guide with a full parts list might work but couldn't find any last night. At least now I know I know it has no feedback, which I didn't before & I also found some info on the motor. Thanks SQ
Old 7th February 2013, 12:02 AM   #26
This may be a silly question, but would any of the DC motor speed controllers be better than nothing on my motor? Obviously I would have to find a 9v one first as they all seem to start at 12v. I can make casework for it at work. Thanks
Old 7th February 2013, 12:09 AM   #27
How about something like this? None seem to mention any form of feedback but that might be because they assume I should know its there!!!
http://www.ebay.co.uk/itm/New-DC-6V-...item35bf09c831
Old 7th February 2013, 12:30 AM   #28
kevinkr's Avatar
If this is the timaudio motor pod it has an integral speed controller built into the motor. Speed stability is OK in my limited experience. (I gave one away with a diy TT that I designed to use it, the recipient as far as I know is still using it regularly.)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 7th February 2013, 12:53 AM   #29
You are right, stability is OK for the price but I'd still like to improve it even with my limited electronic ability. You have given me a bit more confidence in it though, I have to admit.
Old 7th February 2013, 01:05 AM   #30
kevinkr's Avatar
I'm doubtful that you would achieve any meaningful improvement, the motor itself I suspect has relatively modest performance. Just don't overload it as you have noted, print out a stroboscope at Vinyl Engine | The Home of the Turntable, enjoy your new table, and when that motor does finally wear out perhaps go for something like this: Origin Live | Turntable Power Supply (note that I have not tried one, and they are not without some controversy, and the kit is likely to be costly unless you can find a used one somewhere)
Turntable bearing question.Hide this!Advertise here!
Other bearing for turntable use? Zero One Analogue Source 9 8th November 2017 05:22 AM
Bearing for turntable ste Analogue Source 2 2nd August 2010 06:26 PM
Turntable bearing question dod996 Analogue Source 15 4th June 2010 04:49 AM
Turntable bearing Tee-Rex Analogue Source 3 5th May 2005 06:55 PM
turntable bearing design sc351cobra Analogue Source 1 24th March 2005 10:30 AM
