DIY Phono Pre- Boozehound OR Elliot P06?
Old 11th March 2013, 05:38 AM   #11
Hikari1 is offline Hikari1  United States
I've built the boozehound. After break in it was clearly better than the phono stage in my Carver C1 (which was better than my phono stage in a 90's Rotel integrated). Even after I upgraded the opamps and caps in the c1 the boozehound killed it. I run it off 16 AA batteries...it seems sensitive to voltage. 22-26V it's good. After that it drops in gain and SQ. I'd like to try a linear supply with it someday.
Highly recommend the boozehound. Seems expensive till you realize there are 4 matched toshiba 2sk170's in there and PIO caps.
Old 11th March 2013, 05:50 AM   #12
garpt is offline garpt  United States
Agreed. It definitely beats my Lehmann (early) Black Cube and Phonomena.
I also run batteries, 2 12volt SLA batteries. I've run as low as 18VDC, and I agree 22 volts (or up to 24) is definitely the sweet spot. I am still building other DIY preamps because it's fun and inexpensive. What I would like to gain, over the Boozehound, is:
*Better mid definition
*Although good bass extension, a bit flabby at times- Tighter Bass.
High end is good, but perhaps a bit better extension- a bit of rolloff noticed.
This is mostly "nitpicking", as for $90, it is already beating $600 preamps.
Not bad!!
-Gary
Old 11th March 2013, 03:35 PM   #13
Originally Posted by audiorasp View Post
Yes, there are pcbs available.
On Pavel's homepage click on pricelist:
Pavel Macura audiopage
I emailed Pavel-
Unfortunately, he is busy with other ventures right now and not producing any more PCB's. And I don't trust my skills in assembling without a pre- etched PCB. But I really like the looks of that design, with all those J-FET's it must sound really nice!
I found a PCB project on Ebay (from Israel, I believe). It uses 3 AD706 op-amps.
Not sure what the third IC is (Buffer?) but it is an interesting looking design, so for $10, I said "what the heck?"
Is anyone familiar with that model- OR the Analog Devices 706 op-amp for a use such as this? There is frightfully little on the internet about this design, Or that op-amp.
Thanks!
Gary
DIY Phono Pre- Boozehound OR Elliot P06?Hide this!Advertise here!
Resistors suggestions for Boozehound Jfet phono pre, etc.? audio mind Analogue Source 40 26th April 2016 05:41 AM
DIY tube/phono pre in the same case as my DIY dac? ben62670 Analogue Source 3 29th October 2010 09:46 AM
Rod Elliot P06 Riaa problem gchrist Solid State 32 24th September 2004 04:14 PM
Looking for a diy phono pre Tazzy Analogue Source 1 3rd November 2003 01:50 PM
Copyright ©1999-2017 diyAudio
