rega arm rewire
rega arm rewire
Old 1st August 2013, 04:46 PM   #91
GKF is offline GKF  Canada
GKF's Avatar
Originally Posted by soundchaser001 View Post
Hi GKF;
Is that an exploded parts list/diagram of an RB300 I see in the background? Can I get a copy if it is? I am a vinylengine site member and have not seen it there.
Nice work and thanks
Matt
hey matt
yes i downloaded it from a uk based site but can't remember the name.
i'll have a look for the sheet and let you know.
thanks
gordie
Old 1st August 2013, 05:38 PM   #92
SigFire is offline SigFire
rega arm rewire
Default Hope this helps
I think it was this website:
http://www.audiomods.co.uk/images/re...destructed.jpg
Greez
SigFire
S.K.
Old 1st August 2013, 05:58 PM   #93
soundchaser001 is offline soundchaser001  Canada
soundchaser001's Avatar
Smile Thanks!
Thanks a lot guys!
Old 1st August 2013, 06:02 PM   #94
GKF's Avatar
yes thats the one , thank you sigfire for posting this link.
saves me some work and helps matt .
good stuff.
ps sorry i haven't posted any updates in my arm rewire but i've been loving the mods so much that every night i spend 3 to 5 hours listening .
this path i took was the best improvement and shock as how good it turned out.
worth every hour of work and every dollar it cost.
i love the rewire upgrade.
Old 2nd August 2013, 03:39 PM   #95
ticktock is offline ticktock  Scotland
ticktock's Avatar
Originally Posted by MrPig View Post
Yes, Heybrook were an English company who made a lot of well respected and loved equipment.
Wasn't Heybrook based in Glasgow/Scotland (like Linn too)?
thanks
Blaue Leuchtdioden machen blöd. (hb)
sent from NSA monitored device
Old 9th October 2016, 09:20 AM   #96
hazard500 is offline hazard500  Australia
Hi Guys, don't if anyone is still following this thread after 3 years ... but i have a question about Rega tone arm and balanced operation.
I've just finished building my new balanced phone stage (design by Forum member polyphase). My main turntable (customised Lenco with MG-1 air bearing arm) is being serviced right now so i got my old old table out of mothballs - an AR turntable with Rega RB300arm. The new phono amp has 3.5mm TRS jacks, so i desoldered the RCA plugs from the old table and replaced them with 3.5mm TRS plugs.
Plug in right channel - and I hear music. Plug in left channel - the right channel goes to pot, as if its being severely overloaded. Nothing coming out of left channel. I've tried to trouble shoot with my good fiend Google, I have found a thread on Auidogon talking about the need to re-wire Rega arms before you can use the in balanced mode. So - I am hoping that the issues I am hearing are due to arm wiring, not because I have screwed up my phono amp.
Right now, I am playing The Angry Young Them - mono press. I can plug the right channel (red/green wires) from the turntable into either input of the pre-amp and get music, so both channels of the pre-amp work OK. As soon as I plug in left channel (white/blue wires) from the turntable then it goes to crap. So seems like the pre-amp is working. So is it correct - I need to modify the rega for balanced operation? Other options are:
1. Play mono records and listen to one speaker
2. Wait for the Lenco to come back.
Any thought? Thanks guys.
Old 9th October 2016, 10:07 AM   #97
R.I.P.
Is there a connection between the cartridge channels?
Is the sleeve of the TRS cable connector only connected to screen/shield and chassis?
Does connecting Blu/Wht alone give any sound in any channel?
regards Andrew T.
Old 9th October 2016, 11:02 AM   #98
Hi Andrew thanks for getting back to me, all good questions that I should have checked for myself.
1. Ive just checked for connection between channels with my DVM. Does not appear to be any connection.
2. The sleeve is not connected to anything. Cartridge cables go to tip and ring, and from the jack the signal goes to +ve and -ve inputs but the sleeve tag on the input jack is not connected to anything.
3. Good question. I have to go to work tomorrow so I have shut down for the night (hey its 10pm here). I will check this again tomorrow.
Thanks again Andrew. I listened to Sgt Pepper mono tonight, if I dont get this sorted I guess that I can listen to the rest of my Beatles mono box while I wait for my Lenco!
Hazard
Sent from my SM-G900I using Tapatalk
Old 9th October 2016, 07:44 PM   #99
Hamish119 is offline Hamish119  Europe
Originally Posted by hazard500 View Post
...So is it correct - I need to modify the rega for balanced operation?
You most definitely need to modify the 'standard' REGA for balanced operation - see this from here.
WARNING: The following link shows a disturbing image of manufacturer mis-wiring of a tone-arm.
The deliberate connection between the BLUE & BLACK leads is horrific!
The BLACK lead should be extended to the headshell (the missing' 5th wire).
However, the horror doesn't end with the tone-arm wiring.
Many cartridge manufacturers are also guilty of using a SIGNAL pin (usually a - pin) to connect the cartridge body casing to an imaginary ground instead of using the 'missing' 5th wire in the tone-arm.
The 'smarter' manufacturers make it easy to identify and correct their wiring error.
Example - see the source of imbalance on the GREEN signal pin, which should be disconnected from the GREEN pin and connected to the 'missing' 5th wire in the tone-arm.
Good Luck!
EDIT: Every tone-arm should present a minimum of 5 x wires at the headshell (4 x SIGNAL leads + GROUND lead).
Differential input phono amplifiers - the correct method of amplifying the output from a phono cartridge!
Old 9th October 2016, 09:28 PM   #100
Good Luck!
That's great, thanks Hamish. So its clear from this why the right channel works, but not the left channel.
Looks like I got some work to do on my tonearm. Question, if I disconnect the ground from the left channel and don't reconnect the black wire 9just because I'm lazy) what happens?
Hazard
rega arm rewireHide this!Advertise here!
WTB: Rega RB250 or RB300 in need of rewire beeah Swap Meet 0 15th December 2011 03:11 PM
Rega R200 rewire AdrianStone Analogue Source 0 6th October 2008 09:45 PM
rewire Rega RB250 dafdesign Analogue Source 3 7th August 2007 04:13 AM
rewire Rega P3 dafdesign Analogue Source 3 19th July 2007 01:55 PM
