Old 12th January 2013, 11:54 AM   #1
Default Arcam Alpha 7 Tuner Display Issue
Hi
I'd be most grateful for any advice.
I was recently given a "faulty" Arcam Alpha 7 Tuner when I bought an Alpha 8 CD player.
Apart from one mechanically stuck preset button (which I've fixed) the only other issue appears to be two dead segments in the right hand digit of the display. This shows the selected preset channel and is a bit irritating as you can't tell some numbers apart.
Is this likely to be a duff display or a connection / dry joint issue?
Also, the case has a "take static precautions" warning. Is this just a general wise precaution or is there anything wildly sensitivity about these units?
I've done a bit of small electronic work in the past but am no expert by any means.
I'd be very grateful for any advice.
Thanks.
arcam alpha 3 barrowboy Solid State 0 8th January 2012 02:10 PM
Arcam Alpha plus v. Alpha 5 plus v. Rotel RCD 855 dynoPort Digital Source 1 30th March 2011 11:19 AM
arcam alpha 7 big jim Solid State 3 19th June 2006 11:40 AM
Arcam alpha 9 pumpkin Solid State 0 5th October 2005 06:31 PM
Another Arcam alpha 5+ Issue filholder Digital Source 2 19th May 2005 11:40 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
