Pacific RIAA phono pre: failure! - Page 4 - diyAudio
Old 19th January 2013, 12:33 PM   #31
Malefoda's Avatar
Send a message via MSN to Malefoda
The picture on the Spencer's offer thread shows the real Toshibas, I can tell that the one I got had straight legs, not pre-bended... smells more and more fakes.
I'll try to get some from him. And when get them will check capacitance, resistors and volatges without the fets in order to check if they'll settle in the very same environment.
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, TDA1387, UCD400, JBL 4313B: music!
Old 19th January 2013, 12:48 PM   #32
merlin el mago's Avatar
You can trust in Spencer, I'm a happy customer.
Old 19th January 2013, 03:42 PM   #33
Malefoda's Avatar
He asked me "You can select the idss you want" so what I do need?
Old 19th January 2013, 05:13 PM   #34
osscar is offline osscar  Latvia
osscar's Avatar
i use about 8mA idss, but IMHO you can use any from BL range 6 - 10mA (if i remember correctly). In original Pacific circuit they use 5mA idss with 2k4 at drain and without source resistors.
My DIY : http://www.tutribi.net
Old 19th January 2013, 05:16 PM   #35
Malefoda's Avatar
Old 22nd January 2013, 04:34 PM   #36
kevinkr's Avatar
You can use a higher Idss range, but that then requires the use of source resistors which may significantly increase noise. I was going to recommend 5mA Idss based on the value of the drain resistors, a lot of other good members beat me to the punch..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 22nd January 2013, 06:40 PM   #37
Malefoda's Avatar
Hi Kevin, Spencer will send me matched 6.5mA ones, do I need to add these source resistors? In fact there are resistors everywhere, where can I add some more o_O
And if of any use I've put the amp on online circuit simulator.
https://www.circuitlab.com/circuit/g...riaa-prephono/
Old 24th January 2013, 07:39 PM   #38
Malefoda's Avatar
Default Ready...
Here I'm FET-read... voltages all OK, I can only pray now... I've removed the 100R on each source, hope the Toshiba's won't oscillate!
File Type: png Capture décran 2013-01-24 à 21.16.05.png (36.9 KB, 409 views)
Old 2nd February 2013, 09:05 PM   #39
Malefoda's Avatar
A final thanks for support fellows, it's now working like a charm =)
Old 2nd February 2013, 09:08 PM   #40
Congratulations.
Red board add-on phono/RIAA pre-amp rsumperl Tubes / Valves 5 14th May 2011 04:40 PM
How Can I connect A Balanced RIAA Phono Pre-Amp to a Phono Plug amp input jmartinbaugh Analogue Source 3 25th April 2011 01:24 PM
Pacific Riaa codge Analogue Source 5 4th November 2010 11:53 AM
phono pre RIAA 2001 oldeurope Tubes / Valves 5 8th May 2008 09:05 AM
how build usb phono pre riaa tekton364 Analogue Source 2 28th September 2007 08:50 PM
Copyright 1999-2017 diyAudio
