| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#12 |
Oscillation... Good practice to isolate gate from external stray inductance and capacitance, more critical with mosfets than fets, but I have had situations with fairly high transconductance fets that oscillated without gate stoppers. May or may not fix the issue at hand..
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#14 | |
Many thanks, a big hug to ya all ![]() Here is the 100Ω and the tiny 51Ω (it's far smaller than it looks, flash and zoom worsen its appearance, but minimelf and micromelf are a soldering challenge!), and now all flows smooth and dynamic!
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music! |
#17 |
In fact I'm not sure it means " great " but if it's the case: sadly not :'(
Overall volume is louder on left channel. I've cleaned the mess, solder flux, tracks, close matched the 30n with 2x15, it's almost perfect to the eye. But no use... Before I go any further I need to say that I find weird that with only the right IC connected to the turntable I get no sound on left (!) and a very slight level of music on right, then left only connected, no sound on right but a terrific loud bassy mess on left... wtf! May that be some loop at work here? My IC are all connected both wires both sides. So the question is, if there is nothing odd there, how can I fine adjust gain? That's lying on no solid tests but it sounds like a +2/3dB on left most felt at kHz... (I've said it's "à vue de nez" (translate by "seen-by-the-nose") but that's the best I can tell about what I hear, not TT related as inverting left/right does nothing for this). I'm glad I did not started a bigger project! That's so annoying... But I still have to go, time to shift to side B
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music! Last edited by Malefoda; 15th January 2013 at 07:57 PM. |
#18 |
Check the signal with the scope, comparing both channels. Can be a cold joint.
#19 |
Hello Catalonian man
![]() I may be able to check with scope but I don't know when sadly :'( Solder is still warm, a cold joint is unlikely to me, few parts but I'll take a look when I'll manage to scope output signal.
#20 |
Check the tone arm wiring, and does the problem swap to the other channel when you swap the left and right inputs?
Left and right inputs both return to ground somewhere on your nicely built boards? (No opens) Measure dc voltages on fet drains and make sure channel to channel that they match to say within 5 - 10%, if they do not, try to match some fets as variations in transconductance, pinch off voltage, etc. may effect the channel to channel gain match. I would not expect the differences to be that large unless the fets were grossly different. Even better would be to measure the signal levels directly in each stage, verifying that levels match after the first stage, after the passive eq, and finally the second stage. Post a reasonably sized picture of each side of the PCB and let us have a look, perhaps something different between the two channels will stand out. Finally have someone else take a look at your handiwork.
| Red board add-on phono/RIAA pre-amp | rsumperl | Tubes / Valves | 5 | 14th May 2011 04:40 PM |
| How Can I connect A Balanced RIAA Phono Pre-Amp to a Phono Plug amp input | jmartinbaugh | Analogue Source | 3 | 25th April 2011 01:24 PM |
| Pacific Riaa | codge | Analogue Source | 5 | 4th November 2010 11:53 AM |
| phono pre RIAA 2001 | oldeurope | Tubes / Valves | 5 | 8th May 2008 09:05 AM |
| how build usb phono pre riaa | tekton364 | Analogue Source | 2 | 28th September 2007 08:50 PM |
