OPENAMP1 - MM phono preamp open project
Right, thanks Pavel for the information. They surely looks good.
No chance that you would share the gerbers?
I thought I read originally that it was called "OPENAMP1" because it was to be an "open" design, released under creative commons license or some such. Was I hallucinating? Am I confusing this with another project?
It is such a nice design, it would be of benefit to many if it was opened up so someone could organize a group buy or something.
Finallllly got my phono stuff from the x ...
I can finally upgrade my implementation of a pre on PMA's PCB to the full OPENAMP1
Oh ...
BUF634
HIGH OUTPUT CURRENT: 250mA
SLEW RATE: 2000V/ms
PIN-SELECTED BANDWIDTH: 30MHz to 180MHz
LOW QUIESCENT CURRENT: 1.5mA (30MHz BW)
WIDE SUPPLY RANGE: ±2.25 to ±18V
INTERNAL CURRENT LIMIT
ABSOLUTE MAXIMUM RATINGS
Supply Voltage ........................................................... ±18V
SPEC
Current Output, Continuous ±250 mA
LT1010
20MHz Bandwidth
75V/μs Slew Rate (=75,000V/ms)
Drives ±10V Into 75Ω
5mA Quiescent Current
Drives Capacitive Loads > 1μF
Current and Thermal Limit
Operates from Single Supply ≥ 4.5V
Very Low Distortion Operation
Total Supply Voltage ..............................................±22V
Continuous Output Current (Note 2).................. ±150mA
