OPENAMP1 - MM phono preamp open project
Old 5th February 2013, 01:15 PM   #41
PMA is offline PMA  Europe
PMA's Avatar
Maybe there is a misunderstanding, I have not said your OPA627 was a fake. I only would like to warn against cheap parts. It is based on experience that a colleague of mine bought 100 pcs of OPA627 at a very cheap price, and all fakes. There was completely different chip inside with different parameters. Yours looks OK, but it may be hard to tell from the photo. Unfortunately I do not remember who was the seller of the fakes, I will try to find out.
Old 5th February 2013, 03:08 PM   #42
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
Thanks ALD, your eyes are better than mine! That was pretty much what I assumed. With the right type and lead spacing I should be able to source everything from multiple vendors.
Old 5th February 2013, 05:09 PM   #43
AudioLapDance is offline AudioLapDance  Canada
Originally Posted by PMA View Post
..It is based on experience that a colleague of mine bought 100 pcs of OPA627 at a very cheap price, and all fakes. There was completely different chip inside with different parameters...
I'm sure mine are fine as I got them a long time ago from reputable sources however others might want to know ...
Anyway back to OPENAMP1
PMA knows this (because he's always going ooooon and ooooon about EMI! ;-) ) but others might not:
http://www.ti.com/lit/an/sboz016a/sboz016a.pdf
PMA could you talk more about your interesting R2(150ohm)/C2(100pF) filter (10MHz) right at the input? I wonder what that could be about ...
Jeff
PS "EMI and OPA627" could be it's own thread too! Application outside of RIAA ...
Old 5th February 2013, 05:21 PM   #44
Next, when PMA has the time, perhaps he could talk more about the other interesting aspect of his input stage: diodes
Would it have something to do with "diode clamping":
http://www.ti.com/lit/an/sboa011/sboa011.pdf
Or are the diodes for safety ...
Jeff
Old 6th February 2013, 03:03 AM   #45
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
re: diodes
diodes to the rails like that are usually done for protection against transients
mlloyd1
Old 6th February 2013, 03:09 AM   #46
mlloyd1's Avatar
jeff:
see post #33
btw, for the new folks, you can get some good discussion of somewhat similar and other RIAA preamp designs in ADI "app note" here
note: big file but definitely worth downloading and study.
Old 6th February 2013, 06:31 AM   #47
PMA's Avatar
Well, yes. As now, it serves mostly as an RFI filter.
It might, theoretically, improve RIAA response for very high frequencies, if we speak about phono preamp alone, driven from pure voltage source. As you know, non-inverting network has gain no smaller than +1 (0dB), until the opamp's bandwidth will roll it off. R2 C2 could be calculated to allow the RIAA curve continue in attenuation even for very high frequencies above audio band. Please see the attached image.
But, in a real world the phono preamp amplifies signal not from the voltage source, but from MM cartridge, which has output impedance like resistance and inductance in series. Usually 500 ohm - 2000 ohm + 300 mH - 1500 mH. This inductance makes thus a roll-off even for high frequencies and the role of R2C2 described hereabove is valid only in case of voltage source signal (= zero output impedance). And we cannot increase C2 too much because we would load the cartridge by high capacitance and create high resonance peak somewhere between 15 - 20 kHz. We also cannot increase R2 too much for we would get increased noise.
I hope this helps a little, for more on theory please study literature about phono cartridges, like Vogel (The Sound of Silence). Walt Jung's publications are also excellent and may help, but I am not sure if he works with cartridge models in his considerations.
Old 6th February 2013, 07:16 AM   #48
PMA's Avatar
It is based on experience that a colleague of mine bought ....
I have some additional info, it was 2 years ago and "OPA627's" were in TO-99 metal cans and they had input bias current several orders higher than specified in the datasheet. So he did not use them and started complaints/warranty return procedure. I agree that in case of discussion on this subject we should start a separate thread, but I cannnot promise I would be able to spend much time there.
Old 6th February 2013, 05:46 PM   #49
Now, I just got into vinyl a couple of months ago, so correct any newbie mistakes ...
...But, in a real world the phono preamp amplifies signal not from the voltage source, but from MM cartridge, which has output impedance like resistance and inductance in series. ...
I've looked at cart loading before for I didn't include the inductance ...
Wow PMA you weren't kidding! Totally different!
Ortophon tells me my OM5E has:
Internal impedance, DC resistance 750 Ohm
Internal inductance 450 mH
And recommends 200-600pF/47k loading (300pF/47k)
I threw those into the Tina circuit of the 627 and then added just the input of the OPENAMP1:
OPA627 PMA riaa input.zip
Had to zip it, hope it unzips ok
And then simmed (1 to 100k) with the RF filt (150/100pF)
3.4dB boost at 10.2k
And then simmed with no RF filt
2.4dB boost at 10.9k
I didn't think it would matter being a 10Mhz filter but I guess it interacts with all the other input parameters:
So a 3.4dB boost at 10.2k with the RF filter but only a 2.4dB boost at 10.9k with out! Wow, wasn't expecting that ... but it is a small difference.
Hmmmm
Old 6th February 2013, 05:58 PM   #50
PMA's Avatar
Yes, but you would need to sim the whole circuit, to get the correct answer. This was done, for various Rs, Ls, R2 and C2.
OPENAMP1 - MM phono preamp open projectHide this!Advertise here!
Swiss Physics model 5 preamp MM phono input Eric Tang Analogue Source 14 21st June 2015 06:02 PM
Best rbb transistor, for MM phono preamp claudio Solid State 27 31st January 2013 12:58 AM
MM phono preamp with accu and solarcells Koifarm Analogue Source 5 4th November 2012 09:32 AM
Phono preamp mm cartier20002000 Analogue Source 8 27th November 2007 03:17 AM
LT1028 mm phono preamp? miziq Analogue Source 9 27th April 2007 05:10 AM
