OPENAMP1 - MM phono preamp open project
Old 18th December 2015, 07:40 AM   #171
PMA is offline PMA  Europe
PMA's Avatar
Wow!
May I ask what opamp are you using now? It should be definitely JFET input type because of the resistance against RFI, OPA134 is a decent opamp at a reasonable price and will make a good job in the OPENAMP1.
Old 18th December 2015, 07:16 PM   #172
tER299 is offline tER299  Netherlands
I'm currently using a OP177 because I got 2 free when ordering them. I'm thinking about going with a OPA827, since it's cheaper than the OPA627, but I'll order the OPA134 in the meantime. Thanks again for the advice
Old 18th December 2015, 07:35 PM   #173
PMA's Avatar
OPA827 should be fine, but there is no DIP version in production, only SMD package. So, OPA134 would be easier to use for you.
OP177 is not usable (SR = 0,3V/us), just only for the first test.
Old 6th February 2016, 11:57 PM   #174
Well, I finally got around to finishing the preamp. Finally able to listen to my records again!
Turns out the housekeeper broke my turntable needle, so I can't hear anything from the left side -_-
Well, it sounds pretty much noiseless when hooked up to an old iPod, and I'm using the OPA134, so there's still more room for improvement
Thanks for all the help and the design Pavel!
Old 7th February 2016, 08:52 AM   #175
PMA's Avatar
Glad to hear you have successfully completed your preamp. OPA134 is fine, you can keep it. OPA627 will give you only a slight improvement in case that the needle is not in the groove yet . Once in the groove, there will be no difference, the groove noise will completely mask it.
Old 4th November 2017, 06:42 AM   #176
gigigirl is offline gigigirl
Hi, Does anyone know if boards are still available, Looks a very interesting phono to build. Cheers
Old 4th November 2017, 08:18 AM   #177
PMA's Avatar
I am sorry they are not, as I finished all audio kit sales in 2012. However, everything you need for it is published on my web page
Preamplifier for MM cartridge
OPENAMP1 - MM phono preamp open projectHide this!Advertise here!
Swiss Physics model 5 preamp MM phono input Eric Tang Analogue Source 14 21st June 2015 06:02 PM
Best rbb transistor, for MM phono preamp claudio Solid State 27 31st January 2013 12:58 AM
MM phono preamp with accu and solarcells Koifarm Analogue Source 5 4th November 2012 09:32 AM
Phono preamp mm cartier20002000 Analogue Source 8 27th November 2007 03:17 AM
LT1028 mm phono preamp? miziq Analogue Source 9 27th April 2007 05:10 AM
