OPENAMP1 - MM phono preamp open project - Page 6 - diyAudio
Old 6th February 2013, 06:59 PM   #51
And with 500pF/47k as cart load (the high end of the recommended capacitance)
With RF filt:
4.7dB @ 8.7k
Without RF filt:
4.1dB @ 9.3k
Hmmm....
PS I was trying to isolate the input circuitry and see what it does ... and unfortunately TINA doesn't have an LT1010 model :-(
Old 6th February 2013, 07:03 PM   #52
PMA is offline PMA  Europe
PMA's Avatar
Do not add any capacitance. Please see that additional input capacitor is zero in the BOM. Keep only C2, indexed as per my schematics. Your different indexes are confusing the issue and may be misleading for other readers. Please do not modify the part values if building the preamp.
Pavel Macura
http://pmacura.cz/audiopage.html
Old 6th February 2013, 07:41 PM   #53
PMA's Avatar
Just two pics:
Pavel Macura
Old 6th February 2013, 07:52 PM   #54
Sorry Pavel, you were right.
Simming the rest of circuit isolated the RF filter from loading the cartridge.
Ok, no C1 capacitor and just assume 150pF as the value to account for cable capacitance. I've updated my circuit.
With the RF filt (R2=150ohm, C2=100pF) there's a difference at 50MHz:
With RF filt
5MHz @ -195dB
Without RF filt
5MHz @ -180dB
TINA didn't have LT1010 but it did have BUF634 so I used that just to see the basic frequency response. Here's the TINA circuit with the BUF634.
And the TINA file:
PMA riaa OPA627 BUF634.zip
Anyone know where to get a LT1010 TINA model? I think there's a LTspice4 model of the 1010 ... how to import ...
PS Sorry for screwing up your thread, I've corrected all the typos I think ...
Old 6th February 2013, 08:16 PM   #55
PMA's Avatar
You will get the same sim results for buf634 and lt1010 regarding freq response. Please keep C1 = 0 and C2 = 100p, as written in the manual and the bom.
Pavel Macura
Old 6th February 2013, 10:00 PM   #56
Linear Technology had a similar circuit many years ago for their LT1115. I was surprised it is still on the LT website. Here it is. LT1115 - Ultra-Low Noise, Low Distortion, Audio Op Amp - Linear Technology
Ray
Old 7th February 2013, 03:48 AM   #57
Here's the TINA circuit with 627, BUF634, OP07:
And the TINA file:
PMA riaa OPA627 BUF634 wservo.zip
I found a LT1010 spice model and tried to import it but it peaked the freq response?!?
http://cds.linear.com/docs/en/softwa...ion/LT1010.txt
Old 7th February 2013, 04:07 AM   #58
I think I got it! I successfully imported the LT1010 spice file and assigned some pins ...
OPENAMP1 TINA schematic
Frequency Response 20-30k
And TINA file
PMA riaa OPA627 LT1010 OP07.zip
Old 7th February 2013, 08:32 AM   #59
PMA's Avatar
Looks good!
Pavel Macura
Old 7th February 2013, 08:36 AM   #60
PMA's Avatar
Ray
Yes it is similar, but for MM we preferably use JFET input opamps with reasonably low voltage noise, for the reason of almost no current noise added. Remember that above 1kHz the noise in MM preamp is dominated by the 47k standardized load resistor (just one comment here, reducing load resistance below 47k increases resulting noise!!!!!!! - for the reason of character of MM cartridge impedance). BJT opamps like AD797 are definitely the choice for MC preamps.
Pavel Macura
Swiss Physics model 5 preamp MM phono input Eric Tang Analogue Source 14 21st June 2015 07:02 PM
Best rbb transistor, for MM phono preamp claudio Solid State 27 31st January 2013 01:58 AM
MM phono preamp with accu and solarcells Koifarm Analogue Source 5 4th November 2012 10:32 AM
Phono preamp mm cartier20002000 Analogue Source 8 27th November 2007 04:17 AM
LT1028 mm phono preamp? miziq Analogue Source 9 27th April 2007 06:10 AM
Copyright 1999-2017 diyAudio
