OPENAMP1 - MM phono preamp open project - Page 14 - diyAudio
Old 10th August 2013, 08:10 PM   #131
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
Originally Posted by PMA View Post
At what output current do you set your shunt regulator? Openamp board should consume about 70mA per rail.
Yes, this regulator could safely power 3 of those boards! Some folks say that when the shunt MOSFETs are passing a considerable amount of current, the output impedance is lower and it "sounds better". So I have the constant current source set at about 280mA per rail. The regulator circuit itself will consume a few tens of milliamps, I'm not sure how much. The rest is shunted to ground less whatever is used by the Openamp board. It runs a little warm, but not too bad. Certainly the Openamp isn't putting any strain on it!
Old 11th August 2013, 05:55 PM   #132
PMA is offline PMA  Europe
PMA's Avatar
Default BOM, prices etc.
For those who are sending me requests to provide them with documentation, BOM, prices etc. - please consider that all this info is accessible from my webpage, Pavel Macura audiopage
Documentation and BOM is here:
Preamplifier for MM cartridge
prices:
http://web.telecom.cz/macura/pricelist.pdf
Thanks,
Pavel
Pavel Macura
http://pmacura.cz/audiopage.html
Old 29th August 2013, 11:56 AM   #133
Benedetto's Avatar
Stupid question, but:
what does 1F CF3 mean ?
Thxalot
preregulatorpeterE-MAIL
Old 29th August 2013, 12:18 PM   #134
PMA's Avatar
Labeling of this distributor:
CF3-1M0/J | GM electronic
You may use the caps as in the pdf attachment.
Pavel Macura
Old 29th August 2013, 01:11 PM   #135
Benedetto's Avatar
Ok,
so it appears to be just a simple MKT.
thanx.
Old 29th August 2013, 01:18 PM   #136
PMA's Avatar
Exactly. Enough for DC servo.
Pavel Macura
Old 8th September 2013, 08:27 AM   #137
Hi Pavel, I had a quick look on the site and through the PDF but must have missed it, can you let me know the board dimensions please?
Old 8th September 2013, 08:45 AM   #138
Marra is online now Marra  United Kingdom
The boards measure 135mm x 100mm and are very good quality.
Old 8th September 2013, 09:18 AM   #139
PMA's Avatar
Hi all, sorry I probably have forgotten to mention board dimensions. They are 100 x 134 (135) mm. Thanks Marra for posting the information here.
The boards dimensions should be measurable from manual, page 9, if it is printed as 1 : 1 (no scale for printer).
Unfortunately, all boards are sold out at the moment. I hope to repeat the production and distribution sometimes in future, when I get some time to do it again.
Pavel Macura
Old 8th September 2013, 09:21 AM   #140
Ah that's a shame, thanks
Swiss Physics model 5 preamp MM phono input Eric Tang Analogue Source 14 21st June 2015 07:02 PM
Best rbb transistor, for MM phono preamp claudio Solid State 27 31st January 2013 01:58 AM
MM phono preamp with accu and solarcells Koifarm Analogue Source 5 4th November 2012 10:32 AM
Phono preamp mm cartier20002000 Analogue Source 8 27th November 2007 04:17 AM
LT1028 mm phono preamp? miziq Analogue Source 9 27th April 2007 06:10 AM
Copyright 1999-2017 diyAudio
