OPENAMP1 - MM phono preamp open project - Page 12 - diyAudio
Old 3rd August 2013, 07:14 PM   #111
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
Default Superb!
So today I powered it up again and checked the offset on the outputs. I measured 0.0 mV on both channels, so I guess that servo works OK!
Until now my old Thorens TD160 with Signet TK-7e cart was hooked up to the phono section of my old Arcam Delta-290 integrated amp, which in turn was connected to my DCB1 preamp. I replaced the Arcam with the OpenAmp1 today. Cranked up the volume on the DCB1, heard no hum or noise. Next I put on "Tales of a Courtesan" by the Toshiko Akiyoshi Lew Tabackin Big Band. Fantastic! I think the OpenAmp1 has a little more gain and less noise (not that the Arcam was noisy). I don't generally spend a lot of time comparing amplifiers, and the Arcam sounded great, but I found dynamics were excellent, low frequencies a little better. Trombones and saxes had a nice "raw" sound. The only drawback is that my phono stage and preamp are both DC coupled, so the phono system is a little more sensitive to footfalls (I think I need to tune the suspension of the Thorens a little better). I can see the woofers of my Pluto 2's dancing if I walk near the TT! I think the Arcam had a subsonic roll-off.
Anyway, thanks Pavel, it sounds great, and now I am DIY from phono input to speakers (and even the Thorens has some mods).
Old 3rd August 2013, 08:57 PM   #112
PMA is offline PMA  Europe
PMA's Avatar
Thanks for your feedback. As I am not very active in audio now, I have not "advertised" much this project. Anyway, it has had several builders, all of them very satisfied and no one has had any problems. Also listening tests and comparisons were made with excellent results.
Pavel Macura
http://pmacura.cz/audiopage.html
Old 5th August 2013, 07:18 AM   #113
PMA's Avatar
I assume this should be solvable. I have Technics SL-1200MkII, and it is perfectly resistant against steps or mechanical impacts. My system is all DC coupled as well. Maybe to place some shock absorbing pad under the turntable?
Pavel Macura
Old 5th August 2013, 10:16 AM   #114
PMA, are you considering anytime soon to start another group buy of OPENAMP1 pcbs? I would be really interested.
Old 5th August 2013, 11:49 AM   #115
PMA's Avatar
I am receiving requests for PCB boards regularly, so yes, I will most probably start a new production batch of PCBs soon.
P.S.: the PCBs will be available in about 2 weeks from now.
Pavel Macura
Old 5th August 2013, 01:57 PM   #116
Marra is offline Marra  United Kingdom
Good news indeed
Old 5th August 2013, 02:03 PM   #117
It seems that Christmas will come sooner this year
Old 5th August 2013, 05:51 PM   #118
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
these posts remind me that once i hooked mine up and started listening, i forgot to come back and give my comments
it's great!
i think it sounds superb with both my old Shure V15 MR and AT-440MLa catridges
thanks, PMA!
mlloyd1
Old 5th August 2013, 05:55 PM   #119
Pavel will we order pcb's on your website?
Marra
Old 6th August 2013, 08:52 AM   #120
PMA's Avatar
Everyone who is interested in PCBs please send me an e-mail. I will announce when the boards are produced (expected date is August 20). I have a PP account, so I can send PP requests when to boards are finished. I do not plan to open web shop etc., as this is a one-time action and the time I can spend with audio is limited.
Pavel Macura
Swiss Physics model 5 preamp MM phono input Eric Tang Analogue Source 14 21st June 2015 06:02 PM
Best rbb transistor, for MM phono preamp claudio Solid State 27 31st January 2013 12:58 AM
MM phono preamp with accu and solarcells Koifarm Analogue Source 5 4th November 2012 09:32 AM
Phono preamp mm cartier20002000 Analogue Source 8 27th November 2007 03:17 AM
LT1028 mm phono preamp? miziq Analogue Source 9 27th April 2007 05:10 AM
Copyright 1999-2017 diyAudio
