OPENAMP1 - MM phono preamp open project - Page 11 - diyAudio
Old 14th April 2013, 06:20 AM   #101
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
nezbleu:
lookin' good!
mlloyd1
Old 14th April 2013, 08:15 AM   #102
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by nezbleu View Post
I finished this board recently, now working on the power supply. It will be a while yet before I can listen. I also just acquired a low-output MC cartridge, so will eventually have to make some decisions
One of the builders uses step up transformers for MC. I heard it, sounds pretty good.
Pavel Macura
http://pmacura.cz/audiopage.html
Old 14th April 2013, 05:51 PM   #103
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
No doubt, but I hope you aren't trying to limit me to just one phono pre-amp!
Old 14th April 2013, 06:29 PM   #104
Marra is offline Marra  United Kingdom
Sorry if I've missed it but are pcb's still available?
Old 14th April 2013, 07:37 PM   #105
PMA's Avatar
Of course not, I thought you wanted to use this one for MC.
Pavel Macura
Old 14th April 2013, 07:38 PM   #106
PMA's Avatar
Not now, sorry. I hope to get more time for production and distribution in future.
Pavel Macura
Old 14th April 2013, 08:09 PM   #107
Thanks PMA I will keep my fingers crossed.
Old 17th April 2013, 02:31 PM   #108
Default some thoughts
Having worked with similar circuits - derived from the Cello Palette preamplifier - and used in both low and high-gain applications;
1. Add an OPA633 to the "buffer list".
2. the 627 can oscillate under certain conditions. C3 may be necessary - start with 100pf and work up or down.
3. Since the output offset of the 627 can be trimmed, the servo might be unnecessary. Some folks don't like servos.
Charles
Old 17th April 2013, 03:39 PM   #109
PMA's Avatar
OPA627 does not oscillate in this circuit, for 100%. C3 might be important for another opamps. But, R5, that might have been overlooked, is important for unconditional stability.
Pavel Macura
Old 3rd August 2013, 05:00 AM   #110
nezbleu's Avatar
This has dragged on quite a while now. The case work took longer than I expected, partly because I ordered a chassis that is too small to fit everything. I had to offset the boards vertically so they could overlap horizontally.
I mounted the raw DC supply in a separate chassis:
The Salas shunt regulators powered up nicely:
External view: DSC_4885.JPG
This weekend I will double-check for output offset, and hopefully start to listen!
Swiss Physics model 5 preamp MM phono input Eric Tang Analogue Source 14 21st June 2015 07:02 PM
Best rbb transistor, for MM phono preamp claudio Solid State 27 31st January 2013 01:58 AM
MM phono preamp with accu and solarcells Koifarm Analogue Source 5 4th November 2012 10:32 AM
Phono preamp mm cartier20002000 Analogue Source 8 27th November 2007 04:17 AM
LT1028 mm phono preamp? miziq Analogue Source 9 27th April 2007 06:10 AM
Copyright 1999-2017 diyAudio
