Old 27th December 2012, 07:11 AM   #1
bullpeters's Avatar
Location: Right next to beach, a potatoe toss to the whitewater
Default South coast NSW antenna for ABC radio
Need to make an Antenna for my "new" troughline. Roof mounted, simple, probably only listening to JJJ and classic FM. (101.5 and 102.5? something like that) and I am assuming coming in from the same direction. Anyone else like me prepared to share there set up?
I see heaps of stuff on the net, big question is directional or not? I am sure they come from the same repeater, so maybe a YAGI?
Happy holidays
Old 27th December 2012, 08:27 AM   #2
You do want directional. Tuners work much better with the antenna ignoring reflected (multipath) signals coming in from the sides. Yagis are good, I had a 6 element back in the UK in a poor signal area.
Old 27th December 2012, 08:38 AM   #3
freax is offline freax  Australia
Owner and operator of irc.tenettenba.info
freax's Avatar
a masthead amplifier won't go wrong if you have gain issues.
I just use a discone for mine, I never listen to FM bcb tho, only aircraft on approach on the air bands.
Aside from that its shortwave whenever I can get the chance to listen in on a 80/40/20 meter inverted vee.
Old 27th December 2012, 10:16 PM   #4
Speedskater's Avatar
For everything you need to know (and much more) about antennas in (and near) the FM broadcast band:
88–108 MHz
http://ham-radio.com/k6sti/index.html
EV's Best Top Rated FM and HD Radio Antenna Guide & Reviews
http://www.dtvusaforum.com/dtv-hdtv-...e-reviews.html
Kevin
Old 27th December 2012, 10:40 PM   #5
You need to assess the conditions.
If you're getting a strong signal you don't want a (very) directional antenna (they're all directional in horizontal polarization). They have a narrow beam and are more difficult to point.
You can ask somebody local to you.
You can test.
How to test:
Get one made from a piece of 300 ohm ladder feeder. Connect it up and see what you get. See if there's any difference between the channels you're interested in. Rotate it. You can buy a ready-made dipole or build something on a piece of board: http://www.wryr.org/Antenna_instructions.pdf
Try indoor first.
In the worst case you resort to an outdoor yagi with an antenna rotator and masthead amp.
That's it, really...
Oh, elevation makes a difference too.
Old 28th December 2012, 03:44 AM   #6
expert in tautology
bear's Avatar
Distance from transmitting source?
Terrain between it and you?
Your height above sea level, and the transmitters?
Your position - the highest point you can put an antenna - compared to the nearby terrain and/or buildings?
Power of the transmitting station(s).
Your area is: A) urban B) suburban C) rural
_-_-bear
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
ABC Radio National; Rock and the New col Music 0 19th June 2011 10:43 PM
Hello From The South Texas Coast MrBigAxe Introductions 8 10th October 2010 05:50 AM
AM Radio Antenna Mark245 Parts 24 28th March 2009 12:42 AM
Any Tube heads near Central coast NSW duderduderini Tubes / Valves 1 19th November 2007 02:16 PM
car radio antenna petercampusa Car Audio 1 29th April 2006 08:21 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
