Old 8th January 2013, 05:04 PM   #21
kevinkr's Avatar
I looked up the 2M Bronze, seems like a reasonably good cartridge so I would be looking at set up, phono pre-amplifier and the like.
I'd probably set the tracking force nearer the high end of the recommended range of 1.4 - 1.7gms..
I also note that it is a line contact type a geometry which is very unforgiving of set up errors so recheck that everything is correct. Lots of guidance to be found at Vinyl Engine | The Home of the Turntable
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 8th January 2013, 05:45 PM   #22
MrPig is offline MrPig  United Kingdom
Originally Posted by gabdx View Post
I think it is the records: turning at lower speed lowers the high pitched sound, music can be heard in the background and is not clipping, only high frequency, I would say ultrasounds as people over 50 cannot hear it.
Does anyone knows of some type of filler that can cover the groove and alter the ultrasonic frequency response?
This is the best forum post I've seen in years! :0)
I'm afraid that without actually hearing your system it's impossible to say what's wrong with it, if anything. Unfortunately, there are no fillers available that might do what you suggests as all previous attempts at groove-filler have been commercial failures due to the unwanted side-effect of rendering the records unplayable.
Are there any Hi-Fi stores nearby that you could ask for help? They could check out your turntable for you.
Old 9th January 2013, 04:44 PM   #23
kevinkr's Avatar
<snip>
<snip>
Otherwise good advice to seek help from a local hifi shop if available.. A member local to you might be able to help as well.
Old 13th January 2013, 01:01 AM   #24
gabdx is offline gabdx  Canada
I agree it is very weird... another possibility is the arm going into distortion for the last part of the song. I imply that the angle at the last record track would accentuate problems and lead to tracking problems for the needle.
Anyways, I am listening music tonight with a 50 $ cd player and the sound is just so awesome...
Old 13th January 2013, 09:54 AM   #25
Hi Indianajo,
to your statement about Rhino Records: I own the double album "Summer Of Love", Rhino RNDA 71106. It is well recorded, of excellent sound quality and not noisy at all. I think Rhino is not the worst repackager of popular music.
Best regards!
Old 19th January 2013, 03:14 AM   #26
I think my set up is perfect... it is accurately picking up high frequency damage or poorly recorded or poor quality mastering records.
Old 19th January 2013, 08:50 AM   #27
It's not quite that simple. A good, well-adjusted turntable should get as much music off the record as possible while ignoring as much of the noise as possible. Top turntables can be astonishingly quiet.
It sounds logical to say that if it picks up the high-frequency information on the recording it will also pick up the noise but it doesn't work that way. The types of sound differ enough that that it's possible to engineer the system to retrieve one while playing down the other.
Old 8th February 2013, 03:52 PM   #28
Hi, I checked the cartridge alignment and stylus shape and it is all good.
Maybe I need to check azimuth and VTA... I have no way to set this accurately and not the tools to lossen the arm.
Old 8th February 2013, 06:28 PM   #29
Could you borrow another turntable to compare? You need a reference point I think, this is getting you nowhere.
Old 8th February 2013, 08:19 PM   #30
indianajo's Avatar
Hifi stores, neighbors with turntables. You urbanites are living in a fantasy land. The last hifi store in 5 counties of 2 states near me closed in 1989. You can buy a vile car audio system or a 6 watt (rated 100 W/ch) 5 way DVD sound system at the Best Buy warehouse, but forget trying it out. Some of my neighbors that I meet at the Goodwill store record bin have a record player that originally retailed for <$200. It probably has a ceramic cartridge.
Diy audio, or listen to your cell phone on bluetooth, that is the modern world. Only if Gabdx lives in Toronto, live support might be just possible.
I corrected the out of level arm on my BIC 960 turntable, by putting a washer under one side of the cartridge. I used my eyes. Same on normality (90 deg) to the record, the cartridge has slots. If you can't see straight or 90 degrees, try reading glasses. About 1 day out of every 1084 days, you can buy a protractor equipped machinist scale at Big Lots (where I got mine). It is way too big for cartridge setting, but you can use it to cut a paper template to compare the angle.
One can't do without it tool is a microscope to look at the stylus tip from time to time; if you value your records. I was given mine when I was 12, but I didn't get much into biology. I did detect a big chunk out of the Grado FTE diamond at about 4 years of age. The Shure M97 I'm using has been fine for 33 years.
Oh, and Mr. Piranha, Rhino records never owned a pressing plant that I knew of. Maybe sometimes they used the good one by mistake. Or maybe they went upscale when they started buying ads on "The Tube" (defunct music video channel on free broadcast TV).
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Trafo bad, or am I bad caxxxxxx Chip Amps 24 3rd May 2011 08:56 AM
Vinyl to CD Recordings caw Digital Source 4 28th January 2007 07:49 PM
Why do many recordings sound so bad? keyser Music 7 24th April 2005 03:22 AM
Bad recordings. Could they care less? Brushpilot Music 12 2nd January 2005 06:37 AM
Particle physicists rescue rare vinyl recordings purplepeople Music 1 30th April 2004 05:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
